I have a hitachi 60vs810, powers up,bulb new and working,all fans work but no picture or sound, can almost see the menu. any help would be great, thanks
  • 2 more comments
  • slammersam1 Apr 30, 2010
    i have a hitachi 60vs810, powers up,bulb new and working,all fans work but no picture or sound, can almost see the menu. any help would be great, if it's the ballast, how do i test it
    THE MENU, YOU CAN SEE IT BUT ALL BLURRY,COULD THE BALLAST CAUSE IT NOT TO HAVE SOUND?
    I MEAN YOU CAN ALMOST SEE THE MENU BUT IT'S SO BLURRY THAT YOU CAN'T READ IT, NO LIGHT ON THE REST OF THE SCREEN
    CAN I CHECK THE OMHS OF THE BALLAST, TO BE SURE
  • 19,396 Answers
Hi.
I cannot understand what you exactly mean when you say that you "can almost see the menu".
If the picture is very dim or dark, and you can only barely see the the on screen menu, then the culprit may be the lamp, the ballast , the optical group, and digital board (eg faulty white balance circuit).
This fault is quite uncommon, and the TV will need to be tested by a technician.
The first part to check is the lamp. Even if the lamp is turned on, in rare occasions you may have a defective lamp, and that may cause the problem.
Testing the lamp with a replacement is the first thing that will be probably done at a workshop, but it may not be convenient from user point of view. The lamp is expensive, and it is not necessarily the problem.
The high voltage board that supplies power to the lamp must be tested. This is called ballast board or lamp power board, and it is connected directly to the lamp.
If lamp and ballast are OK, the next part to test is the optical group and light engine. This is one of the most expensive parts on TV, and it is likely causing the problem, since lamp or ballast causing the problem is quite unlikely.
Making the point of the situation this looks like an uncommon fault that is difficult to diagnose and repair.
As a first thing I suggest calling Hitachi customer care, ringing the number listed on the owners manual. If they offer an affordable repair, better to get a technician to work on TV.
Posted on Apr 30, 2010
  • Ginko
    Ginko Apr 30, 2010
    Hi.
    The ballast does not cause blurred picture, and does not cause picture and no sound.
    I am afraid that you have a faulty DMD board or light engine, or a faulty digital board. The light engine cannot be tested in a simple way. The digital board is tested reading low volts on diagnostic pins indicated in the service manual for the specific model.
    The service manual is available here:Tv Repair Kits :: Service Manuals :: Hitachi :: 60VS810
  • Ginko
    Ginko Apr 30, 2010
    Hi.
    I have seen that you left negative feedback and that your solution had been refunded.
    I gave you professional advice, I am sorry that the solution could not have been fixed in a simple way, as wished.
    I will appreciate if you can change the negative rating given. This does not affect your rights to refund, but only hurts the experts that spent their free time supporting you.
    Thanks and goodbye.
  • 336 Answers
Hi,It sounds like it could be the ballast.The ballast is the board that powers the lamp.The ballast is the one that lets you know if lamp is not responding or if it's not able to power the lamp.This is the most common failure it's symptoms are exactly like the lamp it will,flicker,not turn on at all,get lamp indicator,usually you will hear clicking or attempts to light up the lamp.The ballast is a simple fix and cost less than the price of the lamp,it's usually sitted right next to the lamp.I have a video for a samsung on how to replace it ,it's the same procedure: http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Found the one you need here:http://greenchip.shopjimmy.com/catalog/product/view/id/169785/s/hitachi-ballast-ha01331/ Have a bless one!
Posted on Apr 29, 2010
  • 1 more comment
  • Antonio Cruz Apr 30, 2010
    Hi,What do you mean by blurry? You get a picture that's blurry,with weird colors?
    The ballast is what gives the lamp it's brightness if you are getting a very dim picture is because the ballast is not providing enough power to provide a full brightness.
    yes,you can check if ballast is providing the right voltage (15,000 volts/15 kv)
Tv shuts off when tuned on
FIRST TRY TO UNPLUG SET AND REPLUG IT. BUT IT SOUNDS LIKE YOU HAVE A POWER SUPPLY BOARD PROBLEM. FIND A HONEST TV TECH. THIS IS A GREAT MACHINE.
Nov 11, 2013 | Hitachi 60VS810 60" Rear Projection...
Hi, I have a 60VS810 60inch LCD projection and the blue power light flashes but no picture comes on...i just got it for free so i dont know how it worked before..yesterday i did get a blury pic on the...
Flashes of blue light are fault indications. From the number of flashes occurs at one time switch on, you can get an idea about the faulty section circuit board inside. If you wish to get details about these blinks, check this link.
Mar 14, 2013 | Hitachi 60VS810 60" Rear Projection...
No picture or sound. The power light is on.
Replace bulb and clean dust from all cooling fans including projector assembly.
May 15, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I have a 50vs810 dlp. The blue and red lights flash in sequence when I turn it on.When they stop flashing the red light for the lamp is on. The yv has no volume and no picture. Is it just the bulb or does...
More than likely, it is the bulb. My hitachi 50v715 would come on(light up and show picture) 3 to 30 sec's with out the lamp indictor even lighting up. Put a new bulb in and works great. So I would try a new bulb. Look in your manual for the bulb number. Buy an original hitachi bulb they last a little longer.
Nov 05, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
Hi, I have a 60VS810 60inch LCD projection. Normally when i turn on the TV, theres a blue led that flashes, and when the blue led turns solid, the screen picture appears. My problem now is that the blue...
It could possibly be the power supply unit or the lamp.The power unit is HA01331. cost is about $120.The lamp is UX21514 cost about the same. Hope this is helpful.
Oct 23, 2009 | Hitachi 60VS810 60" Rear Projection...
Picture intermittently goes dim.
How many hours on the lamp timer?  If 10,000 or more the lamp is approaching end of life and should be replaced.  Lamp will dim when approaching end of life rather than just go out.
Jun 03, 2009 | Hitachi 60VS810 60" Rear Projection...
Hitachi 60EX388 Rear Porjection TV
i think its the fan that needs to be replaced. or it could be the bulb.
Try to open the bulb assembly unit and take out the bulb and put it back in. If you have an extra bulb, replace it and see if works. This worked for me. The bulb i bought wasnt compatible
Mar 02, 2008 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
404 people viewed this question
Top Televison & Video Experts
