Question about Coffee Makers & Espresso Machines
Estro magic family coffee machine
Hi there, I need a manual for a estro magic family coffee machine. Can you help?
  • cambel Jul 22, 2008
    I am in need of a manual for Estro Magic De Luxe. I have a machine but no Manual. Can you assist.
  • jarnee Sep 22, 2008
    I too, am looking for Saeco/Estro magic manual.
    Can anyone post a link or do copy?
    Thanks!
    Problem Solver:
  • 16 Answers
Do you need the user's manual or circuit diagrams?
Posted on Jul 25, 2010
  • Patricia Jan 31, 2013
    Hello I need the User's Manual can you help
SOURCE:
My estro vapore has lost pressure. it will not force water through the filter. how or where can I fix?
Hi Some of the old Estros had Cosmic pumps and that was one of their problems. You can switch out the old Cosmic for a Ulka pump. There would be some modifications but not much.
Feb 06, 2010 | Estro Barista
Estro da5p error message "Out of Order 2"
I got a used machine that had been sittign for years. On the first several tries to power up, I got that error message a short while after powring it up. My water jug is installed externally for easy access, and I could see the water wasnt getting up the hose all the way to the machine. So I elevated the water jug by placing it on top, then the water fed and the message didn't appear. This may not have much to do with your situation, but maybe it will help. (Maybe error 2 relates to water shortage) You could remove the back panel and see if water is filling the tubes. (Caution with hot wires)
If you don't have manuals, I saw them here.
http://www.partsguru.com/VendingmodelDA5P.html
Good Luck
Mar 03, 2009 | Estro Barista Athena
Estro magic delux (now saeco i think) water leaks below brew unit
There is a small metal plate with holes below the square funnel shape on the brew unit. This plate has a pink rubber seal and a stem that goes up into the brew unit. The stem is knurled with ridges and is attached to a screw on the plate. The screw has become loose and the plate is not held tight against the seal. Turn the knurled knob clockwise until it tightes the plate against the bottom of the unit. Make sure the plate is centered as I believe there is a slight lip that it recesses into. Should stop the water in the grounds collector. Of course the seal must be in good condition. Paul
Feb 02, 2009 | Saeco Magic De Luxe Espresso Machine
I need a manual for the Starbucks Athena Barista - how can I get one?
I believe this is the URL you want:
http://www.starbucks.com/ourcoffees/Barista_Final_011305.pdf
Jan 11, 2009 | Estro Barista Athena
No power to boiler - cold coffee
Heating element on boiler is defective. Depending on which model magic you have there might be a seperate boiler for the steamer. No power to heat plate would suggest heating element on heat plate has gone bad or worse case there's a malfunction on the pc board of some sort as everything is fed to it. If it is the board, unless it is the magic redesign (rectangle board vs triangle board), it cannot be replaced as saeco does not carry that part any longer.
Nov 20, 2008 | Saeco Magic De Luxe Espresso Machine
Looking for user's manual for Saeco Stratos Expresso Machine
There are a user manual on this site under Saeco/magic de luxe espresso machine.
Aug 09, 2008 | Saeco Magic De Luxe Espresso Machine
Estro Barista Athena Tripping the GFI Circuit
is there a diagram for the coffee holder. i took mine apart to clean it and i am not sure how the spring goes in.
Mar 04, 2008 | Estro Barista Athena
Coffee Makers & Espresso Machines Logo
902 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
