Back to:
Tags:
Maytag Neptune MAH5500B Front Load Washer
My new front loading washer (by 3 users)
posted by proutyp on Mar 25, 2008
my new front loading washer is not spining. It is 3 months old. We have a 12 month warranty and labor
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Vicki1234, posted on Apr 07, 2008
The water doesn't spin out, I have tried less clothes, and still the clothes are soaked at the end of the spin cycle. I need help!
Comment by Guest, posted on Apr 03, 2008
on spin cycle drum does not move or spin water out
Clarification Request
by aborcass, posted on Mar 25, 2008
did you try calling maytag for service, your under warr.
by voyager6528, posted on Mar 25, 2008
Are you using to much soap?
Are you overloading it?
Solution #1
posted on Apr 13, 2008
Not Rated (0)
NickelsWorth
Rank:Apprentice Apprentice
Rating: 70%, 2 votes
Most Maytag front loading clothes washing machines made with a "door locking mechanism" to prevent opening door during a spin cycle. The "door locking mechanism" adjustable and often continued slamming or hard closing of door causes misadjustment of "mechanism" preventing machine from sensing door "locked" and entering a spin cycle. Check alignment of latch mechanism. Machines also produced with a "creative fix" by either factory and/or service technicians using folded paper or cardboard behind latch mounting mechanism to align mechanism; over time paper or cardboard compresses chaning alignment. Check the mechanism alignment before checking electrical boards or switches on motor and belt drive..
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on my new front loading washer:
I don't want to Accept this solution
Solution #2
posted on Mar 30, 2008
Not Rated (0)
dawnn
Rank:Wiz Wiz
Rating: 83%, 71 votes
call whirlpool customer service, they own maytag now, you will be covered under warranty.
Thank You!
Can you Help with these Washing Machines problems?
My washing machine is leaking a stream of water from all...
neptune mah550bww
I have a MAH400AWW and the thing will not drain or spin,...
The softener dispenser flushes the softerner solution out...
How can I open up my machine to clean out gunk in soap...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
