Magellan MAESTRO 3100 98083401 GPS Device Logo
Posted on Mar 25, 2008
Magellan GPS How do i update my GPS (Magellan Maestro 4250 GPS)?
  • todd30075 Mar 29, 2008
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Mar 29, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
0
Helped
465
Points
Online at Magellan website you can update your magellan maestro 3100
3 Related Answers
Anonymous
  • 1689 Answers
  • Posted on Aug 20, 2008
SOURCE: I tried to upgrade my
if you still have the original DVD that came with the device, i think you can use that to upload them maps and other info, but of course this will just be like having the device brand new.
Anonymous
  • 373 Answers
  • Posted on Jan 29, 2009
SOURCE: International Maps for Magellan Maestro 4250 GPS
If I am correct you can put it on the sd card
There should be a slot for the card on the unit .
also you can check on their web page .
Anonymous
  • 677 Answers
  • Posted on Jul 30, 2010
SOURCE: how do i open my magellan gps-maestro 4250-to get
there are 4 screws hidden under the little black rubber plugs on the back of the unit...remove those 4 screws, then slip something small and flat (i use my finger nail) around the area where the back and front of the case meet...there are several snaps that hold it together that youll have to break loose to seperate the back and front....slowly seprate then and disconnect the screen ribbon from the main board...
the screen is only held in by little clips on the sides...just gently pull the case away from the screen in those areas and the screen will pop out
let me know if you need further help
Andrew, I called Magellan support team inquiring about the update on Magellan Maestro. Answer: no longer support Magellan Maestro 4250.
Too bad. I wondered if that was the case. Your message would have been better as an answer to me in your post. I only saw this by chance.
1helpful
Owned 3 Magellan 4250 Gps, was working, now no sound.
Make sure the font selected is a TTS ( text to speech)
Manual and guide book for magellan 4250
you can download a copy off the magellan site HERE and also any updates for your 4250
bill
Just wondering how can i do the up date for my magellan maestro 4250 gps for free
new up date for magellan 4250 just go to www.magellangps.com and click on unit gps thann download the f/m version 4.86 it is free and simple juste follow the step by step body good luck
2helpful
Firmware Update 4.86 failed in mid-update. Maestro 4250 will not respond. Menu screen comes up but will not work.
try and run the firmware update again. make sure the its fully charged or plugged in. this usually works though sometimes it wont depending on what files are missing..they are other ways to fix this problem, but i recommend you call magellan to get it fixed. they will repair any of their gps that were rendered inoperable do to there updates.
you can go here to contact magellan support
2answers
Our Magellan Maestro 4250, came on by itself and will not turn off.
is it plugged to AC charge when it comes on?
If not seek out the RESET hole and place a fine pin or paper clip end in and reset the unit
5helpful
2answers
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
3helpful
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
There is a RESET button on the bottom of the unit on the left side
2answers
Maestro 4250
Maestro 4250 is frozen. HELP ;-(
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
