Xerox copycentre C20 Can send a fax but not receive Help
We are able to send out faxes but not receive. Machine worked fine until today
help please
    New Friend:
  • 44 Answers
Check if your telephone cable is connected at the " tel " plug on the fax machine
Posted on May 19, 2010
I work IT Support. I have a user that cant send/receive fax from xerox phaser 3300 mfp. They can scan/print fine. Thoughts?
check the fax line. Plug that line into the regular fax machine to see if you can receive/send from there. What where you should start. Thanks
Apr 12, 2011 | Computers & Internet
Unable to use upper feeder on CopyCentre C20
Turn the machine off. Disconnect the white cable on the back of the machine. Turn the machine back on let it come to ready.
Turn the machine back off, plug the feeder back on and turn the machine back on.
The machine seems to forget it has the feeder from time to time.
It has to boot up with it unplugged to reset.
Nov 09, 2010 | Xerox CopyCentre C20 Black and White...
Copycentre c20 has open heat error message. How do I replace fuser unit?
The fuser unit for this machine can only be installed by a technician as the fuser unit itself is not for sale to consumers.
Nov 19, 2009 | Xerox CopyCentre C20 Black and White...
Canon 1023if not receiving faxes automatically
Is this fax line shared with the phone? I believe there is a distictive ring setting in the add'l functions area under communication settings then receive settings. you would need to select a ring pattern different so the fax can tell between which types of calls it is receiving.
It has worked for me in serveral other installs
Hope this helps
TankMurdock
Apr 09, 2009 | Canon imageRUNNER 1023iF Black and White...
Can receive a fax, but cannot send fax.
I was told by Xerox support tech that he thought it was the fact that we do not have a dedicated analog phone line, but the fact remains we can receive faxes but cannot send them. The only fax that will send is directly to Xerox support.???. The machine was working fine, faxing (sending and receiving), until about a week or so ago, when we had a repairman here on the printer. He told me to report the problem to our telephone repair service. He is coming out today! I'll let you know.
Feb 19, 2009 | Xerox Phaser 6115MFP/N Laser Printer
NETWORK CARD
The C20 does not have a main board capable of adding a NIC. It has to be a minimum of am M20, M20i has fax capabilities.
Jan 10, 2009 | Xerox Office Equipment & Supplies
Won't send faxes to 817 area code, all others OK
The recipient may have a DSL phone line, or receiving to a fax server that blocks your area code.
Oct 14, 2008 | HP 640 Inkjet Fax Machine
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Replace Drum
Start by trying this.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
      [_]
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Jan 08, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
67 people viewed this question
k24674
