Question about Sony KDF-E60A20 60 in. LCD HDTV
Our Plasma wa sworking great ut then shut off...when we tried turning it on the lamp light started blinking red. Thetv is Sku 73025LD 55 MDwide Screen 1080P 120hz tv. what does this mean??
TVtechmaniac
  • 140 Answers
SOURCE: PICTURE WENT BLANK TV TURNED OFF
Replace the thermal fuse part# 1-910-006-44 You can verify this by jumping the connector where the fuse connects and the lamp will come on.
Posted on Aug 21, 2007
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
rockitman187
  • 2559 Answers
SOURCE: kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Posted on Jan 30, 2009
SOURCE: red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Posted on Feb 09, 2009
SOURCE: TV Wont turn on - Red Blinking Light under Lamp
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
Posted on Apr 16, 2009
TV shutting off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 10, 2014 | Sony KDF-E55A20 55 in. LCD Television
My sony kdf E55a20 does'nt come on ,has two red light's on blinking, the other not
the set may or may not have the self check feature--set off with the Sony remote hit display, 5, vol down and power.
Oct 29, 2012 | Sony KDF-E55A20 55 in. LCD Television
The tv turns on but then shuts down. will not stay on, any ideas why?
If its Sony KDF-42WE655 TV then it has self diagnostic feature and if it gets any problem inside, its red light will start blinking in specific numbers to show an error code.
Let me know how many times its red standby light blinking between 3 seconds interval.
Nov 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
When i try and turn my tv on the power light blinks blue and the fan and lamp light blinks red the everything turns off after about 30sec can i fix this myself
Hi, Does the set come on for about 30 sec.? I had a 50V715 hitachi, it came on for about 30 sec. then shut down and then it would repeat the process. After about 3 wks and alot of other pain, it turned out to be the lamp was weak. Replaced the lamp and all is great! So... it could be your lamp is going bad. Hope this is helpful.
Nov 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 55 inch Hitachi HDTV it is around 3 years old. as of yesterday it was working fine and today it will not turn on. when i press power button i get a buzzing noise and it sounds like it wants to...
If you hear the Lamp fan turn, it is probably the lamp it self that has failed. If you do not hear the lamp fan turn then the fan could be bad or binding.
Hope this helps,
Skyassoc
Jun 28, 2009 | Televison & Video
I HAVE A SONY 55 INCH TV THAT IS NOT WORKING.
Symptoms shows lamp is broken and TV requires new lamp.
Let me know exact model of TV to provide you lamp purchase info.
You can replace lamp easily as procedure is written in user manual.
Mar 28, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Wega KDF-55E2000 won't turn on
A 5 blink code is a lamp power supply problem, but I would try a new lamp. I'd say about 90% of the time that fixes the problem.Get an ORIGINAL Sony lamp as the aftermarket replacements are ****. If you replace the lamp and still have the problem, you will need to have the lamp power supply/lamp ballast replaced
Oct 19, 2008 | Sony Grand WEGA KDF55E2000 55" Projection...
Aug 20, 2007 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E60A20 60 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
