Question about Water Pik Waterpik& Elements& Fixed Mount Showerhead
I have a triton r2 which has suddenly stopp working no water no power there is power at isolating switch
  • 771 Answers
My guess is that the solenoid valve on the inlet pipe has died. This assembly is held closed by water pressure and power is needed to pull it back to allow water through to the heater coils. These systems are designed not to operate in the absence of water flow for safety reasons. The valve will be fine, it is the electrical coil within the solenoid which is at fault. Disconnect the shower unit from the mains supply and disconnect the solenoid terminals, Its the little cylindrical device immediately to the right to the stabiliser valve (the lower knob). Try a voltmeter across the solenoid and it should register some continuity, if no continuity the coil is fried. Triton will be the best place to get a replacement part.
Posted on Apr 30, 2010
Water is coming out of the bottom of unit shower triton t100xr
Sounds like the valve is leaking. TURN THE POWER OFF and isolate the shower from the mains. Call a plumber if you are not competent to repair the valve.
Jul 28, 2017 | Home
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
I have just fitted a new prv to a triton Rapide R2, but it will not operate. no water will run through
What is the prv set at. Some prv are pre set and may reduce the pressure too much preventing your unit from working
Nov 28, 2010 | Home
We have triton cascade power shower and the water keeps coming out even when the power is isolated.
I too am having exactly the same problem with my triton 300 si. I have noticed that since this behaviour started the red light around the on/off switch is no longer illuminated (whether it's on or off).
I have tried calling the technical support but they wont help since it's out of Guarantee. Have you noticed any other features missing or not working?
Aug 01, 2010 | Hansgrohe Showerhead Shower Power ...
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Nov 11, 2009 | Water Pik Waterpik& Elements& Fixed Mount...
Triton Shower is not working at all after a years great service.
FIRST TURN OFF POWER SUPPLY THEN OPEN UP THE CASE AND INSPECT THE WATER PUMP FOR ANY BUILD UP OF SCALE IF SO CLEAN WITH A GOOD SCALE REMOVER, ALSO CHECK THE PUMP IS NOT FAULTY AS THIS COULD BE THE CAUSE OF YOUR PROBLEM , ALSO CHECK FOR ANY LOOSE WIRE CONECTIONS .
Nov 11, 2009 | Home
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Water Pik Waterpik& Elements& Fixed Mount Showerhead  Logo
381 people viewed this question
Top Water Pik Home Experts
Donni Steen
Are you a Water Pik Home Expert? Answer questions, earn points and help others
