Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint Dishwasher BFI620 lights 2 and 4 flashing
I have a Hotpoint BFI620 and have an error with lights 2 and 4 flashing. When the wash cycle starts, it pumps out remaining water, then fills up for the pre-wash rinse but about 10 seconds into the rinse itself, the system drains back out and I get the error message of lights 2 and 4 flashing. Please help!!
SOURCE: dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Posted on Jul 21, 2007
  • 185 Answers
SOURCE: Noisy Dishwasher
has there been any hard objects such as fruit seeds nuts egg shells ect. is it doing it in all the cycles
Posted on Mar 28, 2008
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
SOURCE: hotpoint aquarius fdw20 fault lights
take base plate off and check for debris in the wash pump
Posted on Feb 19, 2009
  • 236 Answers
SOURCE: my carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Posted on Mar 16, 2009
Hotpoint DC28 not washing
1.press cancel button
2.check if the door closes securely.
3.since there is water in d/w try running a short cycle.If it works, clean the inside thoroughly to ensure no clogs.
Jan 12, 2014 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Hotpoint BFI620 - 1st two green lights are flashing & the dishwasher will not start
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Jul 13, 2011 | Dishwashers
The Heavy Duty and the Daily Cycle lights are
to better assist you can you provide me with the ERROR code, if is any.
Thank you
May 15, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Want to replace the heating element
Can you tell me which one is your dishasher to better assist you.
HLD4040NSA
Hotpoint® Built-In Dishwasher
HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher
Thank you
May 12, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint bf162 built-in dishwasher error codes
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Ian
Feb 10, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
HOTPOINT BFI620 one led flash error
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Oct 31, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
131 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
