Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
The Brush Motor on my Bissell Healthyhome Vacuum wont start
The Brush Motor on my Bissell Healthyhome Vacuum will not reset. I have cleared the brushes of obstructions, checked the belt, and still nothing. There is NO trip or reset button on this model at least externally. Is there any way to reset this manually, or a solution that ANYONE can offer, or am I S.O.L.?
I had this same problem. There is a screw that holds the top handle and the lower handle "together". If this screw is not TOTALLY tightly screwed in, this will cause the contacts in the switch to BREAK contact, and therefore one or BOTH motors may not start, or cut in and out. This was the fix for me.
Posted on May 12, 2010
Found the screw in the back of the handle. Sure enough, it was loose. I tightened it down, and it works great now. Thanks!
Posted on Jun 15, 2010
    Problem Solver:
  • 14 Answers
Is the grey "brush" button on the handle turned on? Brush won't turn otherwise.
Posted on Nov 04, 2010
  • Bissell Master
  • 43,501 Answers
Sorry but I think that you are S. O. L.....
The motor is fried and it will probably cost more to fix then that thing is worth...
Wish I could give you better news...
heatman101
Posted on Apr 29, 2010
  • billies114 Apr 05, 2011
    Had the same issue, tightened the screw on the back between top handle and unit and it works perfectly.
  • johnwy Jun 26, 2011
    A vacuum repairmans recommendation to install a $100 computer chip just did not sound right. The beater brush sporadically worked. Tightened the screws you stated and the vacuum works perfectly.
Brush won't turn bissell vacuum 3760-4
No there is no separate fuse, when you did this you caused the drive motor to overheat, this destroyed the belt as you have seen and likely burned out the motor for the brush head..
Dec 06, 2011 | Bissell Vacuums
I need a blue print or picture of the way the brush installs. I took the brush off and the sprocket that attaches the belt from the motor to the brush came off before I saw how it is installed. I am unsure...
hello mcc.....here is a link to the schematics for all of the Bissel products. Find your particular model and you will see the diagram showing exactly how each of the parts fit together.
http://www.searspartsdirect.com/partsdirect/brands-products/Bissell-Parts/Vacuum-Parts
Joe
thanks for choosing Fixya!
Apr 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
The brush will not rotate. I thought this was a direct drive system.
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Check the belt through the clear brush cover. If this appears damaged or broken, please take your machine to a local BISSELL Authorized Service Center to have this replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
If you continue to experience difficulty with this, please take your machine to the following Service Center in your area. The warranty on this machine is five years.
Aug 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
I have a Bissell lift-off revolution. The power won't turn on at all. Tried different outlets. It doesn't work whether the lift-off canister is out of the frame or in the frame. The manual refers to a...
I have the same issue too. Brush motor is working and brush is turning on but the vaccum motor is not working. If I take the canister out of the frame then it wont turn on at all. Any help?
Jul 15, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Beater brush
- Make sure brush switch on the handle is on.
- Check the belt through the clear brush cover. If this appears damaged or broken, take your machine to a local BISSELL Authorized Service Center to have it replaced. If the belt is intact, please continue checking the following:
Jun 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
The brush belt has come off my Bissell 8910. Part
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tey36
Apr 18, 2010 | Bissell 8910 ProHeat Clear View Upright...
Scrub roller wont spin
pull the bottom cover off and replace the drive belt for the brush drum, if the belt is ok then replace the drive motor for the brushes.
Jul 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
My bissell 3595-2 vacuum cleaner started turning off the power automatically. Now I can not get it to turn on. This vacuum cleaner is still in real good condition, as I have hardly used it. Please...
Hello, this is Ava with Think Crucial.
Most Bissell vacuums have Thermal Motor Protection which is a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting. When the motor cools for approximately 30 minutes, the thermal protector automatically resets and cleaning may continue. If the cleaner will not turn on or the thermal protector continues to activate, your cleaner may need servicing.note: the thermal protector controls the main vacuum motor only, not the brush motor. If the thermal protector activates, the brush will continue to operate normally; however, there will be no suction.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 03, 2008 | Bissell Vacuums
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
1,306 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
