Question about HP PSC 2210 All-In-One InkJet Printer
I tried to do a reset (pressing 6 and # when plugging power cord back in, the display scrolls through different langages, but I cannot get it to select English. Can anyone help?
  • 4,041 Answers
Hi
I have had a look in the manual myself for you but not see any F4 there.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
Click LINK= http://www.4all2sell.com/pdf/HP-PSC-2210-2210v-2210xi-Manual.pdf
You will need a adobe reader to see this file If you not got an PDF reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 29, 2010
  • myjunkemail1 Jul 22, 2011
    You need to hold down the power button and the "X" button then unplug your printer. Wait 10 seconds while still holding the buttons down. Plug your printer back in and continue holding the buttons. Wait 5-10 seconds then release and it should recognize your freshly refilled ink tanks! Works for me!!
My power light comes on then ngoes off immediately
1. Turn off the computer
2. Removed battery and disconnected power cord .
3. Wait, for 5-10 minutes
4. Plug the power cord back in but DO NOT reinsert the battery
5. Holding down both the Insert/Scroll button, hold the power button down for 20-30 seconds, release the power button. still hold the Insert/Scroll button press the power button normally should come up and Windows should boot.
6. Restart hit ESC it should open the BIOS and reset to default. restart computer should come back.
Feb 19, 2011 | HP Compaq Presario F500 F700 and G6000...
I cleared a paper jam in my hp officejet 7310xi/all-in-one and i'm still getting a carriage jam message. How can I get the printer back to normal?
Try to Reset your Printer.Before that search for any paper piece or any other obstacle which preventing carriage movement.
Full reset:
a. Unplug the power cable from printer when the printer is powered on.
b. Press and hold # and 6 while plugging in the power cord.
c. Wait until "Semi full reset" displays ("Semi" appears despite the fact this key sequence is defined as a full reset).
d. Answer questions - Language/country, etc.
Partial reset:
b. Press and hold # and 3 while plugging in the power cord.
c. Wait until "partial reset" displays.
I think it helps.
Jan 10, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Printer not aligning after changing cartridge
Once you insert the cartridges, please follow the below steps.
1. Press the Setup button on the control panel.
2. Press the number 6 on the keypad or scroll to Tools.
3. Press 4 on the keypad or scroll to Align Printer. The alignment process starts.
If still the issue is not fixed, please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Apr 18, 2010 | HP Officejet Pro L7680 All-In-One Printer
I have an error message on my printer "Error:0x07a74dd6" please advise
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Reconnect the USB cable, and try to print a print job from the computer
if it don't work then try this
1.Firstly if the printer is connected to a surge protector or any kind of power strip disconnect it from there and connect the printer directly to the wall jack.
2.Even after that if it is not working then you can perform a factory default reset on your machine
a) Leave the printer turned on and then disconnect the power cable from the printer and then press and hold the # and 6 together at the same time while plugging the power cord to the printer and keep on holding the buttons once you see semi-full reset
See whether it works or not
b) In case if it does not work then perform the same thing but instead of # and 6 press and hold # and 9 and the display will read full reset
3.Also try to connect the printer in a different wall outlet and if possible try with different power cable
Mar 17, 2010 | HP OfficeJet 7310 All-In-One InkJet...
When I turn on the printer, it tells me that the right ink side (black)needs to be taken out and re-inserted. I did that, even replacing the cartridge and it didn't help. Can you help?
Hi I only found the may or may not work but it worth a try.
I pressed # and 3 at the same time while plugging the power cord back in
I then made a note of the following messages which display:
selftest
partial reset
initialization
initializing...
used black print cartridge (prompts you to press OK)
used tri-color print cartridge (prompts you to press OK)
displayed date and time as usual
Try the following steps
-disconncet the power cord from the back of the printer
-press and hold # and 6 key simultaneously
-while holding both the keys ...connect the power cord back
- release both the keys
...it will show initilaising ...semi full reset
- see if the error message still persists
Feb 16, 2010 | HP OfficeJet 6210 All-In-One InkJet...
What does it mean when it says scanner failure?
Hello it means that the scanner bulb temperature is too low or there is some internal or external electrical malfunction.Try these solutions.
1.Check the scanner light.Make a color copy of any document by pressing the Start, Copy, Color button on the product control panel.While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
2.Make sure that the room temperature is suitable for your device
3.Perform a Power Cycle on the unit by following the steps below:
1.Turn the unit off.
2.Unplug the power cord from the unit.
3.Wait 30 seconds, and then re-connect the power cord to the unit.
4.Turn the unit on.
5.Make a color copy by pressing the Start Copy Color button on the control panel.
4.Check the power connections.Disconnect the power cord from any power strips or surge suppressors and then plug it directly into a wall outlet.Try making a color copy by pressing the Start Copy Color button on the product control panel.If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
5.Perform a partial reset
1.Disconnect the power cord from the product.
2.Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
3.Try making a color copy by pressing the Start Copy Color button on the product control panel.
6.Perform a semi-full reset(Performing a semi-full reset deletes any saved phone numbers on the product).
2.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
If nothing of these works and you still see the error you should take your printer to support service for repairing the parts.
Feb 08, 2010 | HP OfficeJet d145 InkJet Printer
0xc18a1002 error message on HP Photosmart C-7180 Printer
Resetting HP Photosmart C6180 & C7180 "system failure" errors:
(might work on other similar models as well)
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
Feb 03, 2010 | HP Photosmart C7180 All-In-One InkJet...
Moved my 7410 All-in-One - now it won't power on all the way
Perform power reset :
  1. Disconnect the power cord from the back of the product.
  2. Disconnect the power cord from the electrical outlet, and then wait 60 seconds.
  3. Connect the power cord to the electrical outlet.
  4. Connect the power cord to the back of the product.
  5. Press the Power button to turn on the product.If the issue still persists perform the partial reset steps:
    1. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 3 keys.
    2. Plug the power back into the printer, keep holding the # and 3 keys till you see “ Partial Reset ” displayed on the printer screenIf the issue still persists, perform the semi full reset of the printer.
      1. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 6 keys.
      2. Plug the power back into the printer, keep holding the # and 6 keys till you see “ Semi Full or Semi NVM ” displayed on the printer screen.
Sep 27, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP C7180 how do i do a cold reset for this printer?
7) press CANCEL
8) press CANCEL
9) press CANCEL
NOTE: E_M_R_E_7@HOTMAİL.COM
Jun 30, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP office jet 7310
Please goto the HP website and see if there is a firmware update for this machine. Download and you can also download the procedure.
It seems to be that it's a controller issue and reinstalling the firmware will usually resolve the problem.
Hope can be some help
J
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
220 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
