Question about Kenmore HE2 Plus Front Load Washer
Kenmore HE2. Won't drain. I have gotten the screws off and the panel removed. I see a large round white (I guess the pump/filter thing) with a straight plastic piece across the center. When I try and turn counterclockwise by that straight thing I can't turn it. Is it "normally" really hard to turn? Am I doing it wrong? Do I need to rent a husband? Any help is appreciated.
  • Tracie Kellogg Apr 29, 2010
    Thank you so very much. I don't know what channel locks are but I used a pair of pliers wrapped in normal tape then put a towel under them and FINALLY got it to turn. After a couple pans of water, about a buck in change and then found the REAL culprit. Few months ago started using those new Laundry "Sheets". Look like a dryer sheet but thicker. They have detergent built in them and you can throw them in the dryer with your wet clothes and they double as a dryer sheet. Ironic thing is I've never used dryer sheets but liked the Laundry "Sheets" because they seemed efficient; no mess, no measuring. Well one somehow got through to the drain things and mucked it all up.
    Ran one Rinse/Drain cycle and all seemed fine. Have a big load in now of sheets, etc. Hoping it goes well.
    Never did see an a rubber O ring...Hmmm. Hoping it just didn't have one.
    Did not have the $$ to fix this and have been doing laundry at friends. You have helped a single mom and 2 girls so much.
    THANK YOU THANK YOU THANK YOU
  • 5,911 Answers
You are referring to the drain pump reservior. Yes, they can be difficult to remove sometimes as they have a tight seal. Before you attempt to go any further read through the following link on checking the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
This may provide you with some helpful tips on how to avoid a mess of water coming from the wash tub, drain pump and lines.
If the cap will not come off, and has an open style handle, you can use a screwdriver for leverage. Place the screwdriver in the handle and CAREFULLY turn in a counter-clockwise direction to remove. If the handle is closed, I have found that a set of channel locks (looks like a large set of pliers) can give you the necessary leverage to pop the seal loose. Cover the teeth of the channel locks with electrical tape to prevent marring the pump handle. Again, exercise caution so that you do not break the handle off. Once you have the cap removed, use petrolium jelly on the rubber o-ring and seal the cap tight. The petrolium jelly will help keep the seal, but will make it easier to remove the next time you need to clean it.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Apr 29, 2010
Testimonial: "Could not have done this without this guy. Thank you so very very very much."
  • Jeff Rockwell
    Jeff Rockwell Apr 29, 2010
    Some drain pumps have an o-ring some don't. You can still lubricate the threads of the cap with petrolium jelly and serve the same purpose. I don't know who's bright idea it was to create Laundry sheets, but you aren't the first person I've helped that found them clogging the drain pump and/or drain lines. It seems they are more trouble than they are worth. Probably should recommend that consumers stop using them. I hope things continue to work for you. Keep me in mind if you have any more problems.
Tip
Clean the pump filter screen on a Kenmore HE2 Not draining
  1. Unplug machine.
  2. Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
  3. Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...
  4. Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be careful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris.
  5. Once everything is cleaned out reverse removal procedures put back together.
on Apr 07, 2010 | Kenmore HE2 Plus Front Load Washer
Won't finish cycle 21 F- flashing on panel
F21 error code is indicating that it is taking too long to drain water.
Your details indicate that you are using too much detergent or the wrong type of detergent and causing excessive suds. The drain pump can not pump suds out. The washer requires HE (High Efficiency) detergent formulated for front loading washers.
Cut back on the detergent and it will most likely operate correctly.
NOTES:
* After four (4) minutes the "Sd" error will be displayed, and then four (4) minutes later the "F21" error code will be displayed.
* Press STOP two (2) times to clear the display.
Possible Causes:
- Using too much High Efficiency (HE) detergent and causing too much suds.
- Using NON-HE detergent causing too much suds.
- Kink in drain hose
- Debris or foreign objects in drain pump filter.
The drain filter is located behind the lower access panel.
NOTE: Disconnect the power cord before removing the lower access panel and cleaning out the drain pump filter.
Remove the two screws (key#21) securing access panel. The filter cap (key#14) is removed by turning it counter clockwise. NOTE: Be sure that all the water has pump out before removing the cap. Have some large towels handy because there will be water coming out the filter/pump once you remove the cap. Check and clean the filter and remember to reduce the amount of detergent and the washer should perform as designed
Hope helps (remember to rate and comment this free answer)..
Jun 10, 2011 | Kenmore HE2 Plus Front Load Washer
My kenmore elite mod 42832 has a error code f2 does not drain or spin
Hi
Error F2 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 23, 2011 | Kenmore HE2 Plus Front Load Washer
How do i remove the he2 plus lower panel to clean the filter
Their are three small screws at the bottom of the panel (FLOOR LEVEL) once these are removed you can pull out on the bottom of the panel to remove..Then you can place a shallow pan under the drain pump then remove the cap and strainer to clean......
Nov 16, 2010 | Kenmore HE2 Plus Front Load Washer
The Kenmore HE2 Washer Model 11046462501 Selector dial lights blink continuous with status lights Add a Garment, Rinse, Clothes Clean lights lit. What does this error mean ?
This IS the code for drain problem, pull front panel and remove round filter by turning to the left, probably full of change, feel the pump to the right of the filter if it is HOT, replace it...
Aug 09, 2010 | Kenmore HE2 Plus Front Load Washer
F 21 error code
F21 Long drain Possible cause: Clogged filter, clogged/failed pump. Get the bottom panels screws out and remove it. Tech sheet with erro codes and diagnostics are behind the white motor control box to the left.17faa85.jpg379e38c.jpgccf409c.jpg
May 08, 2010 | Kenmore HE2 Plus Front Load Washer
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
What is f21 on the kenmore he2
"F21" is a Long Drain error. This occurs when the drain time exceeds 8 minutes. You will need to remove the bottom panel under the door by removing the two screws at the bottom edge of the panel. First, check the electrical connections to the drain pump and make sure the pump is running. Check the drain pump filter to make sure it is not clogged with debris. This is a very common problem. HINT: Before removing the drain pump filter, pull the drain hoses from the standpipe at the wall and use a shop vac to pull a vacuum on the drain hose to get rid of all residual water from the pump and drain lines. This is also a good way to get rid of minor clogs. If you do not own a shop vac, be prepared to lay down some old towels and soak up some water. There's quite a bit of residual water in the wash tub and lines (this is normal). In addition, check your drain hoses to make sure they are not clogged or kinked. If you check everything and still have the error code, replace the drain pump. Replacement parts can be found at searspartsdirect.com and repairclinic.com. Just type in your model number in the search menu. I hope this helps you.
pls rate my suggestion....
Jun 24, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2
Yes, it will. There are two screws holding the bottom panel in place that you will need to remove first. Your pump may be constructed differently than the full size HE models. If you do not have a clean out trap, unplug the washer and remove the pump. Flush it with water to clean out the impeller. DO NOT submerge the motor portion in water, however. If you have to remove the pump, just disconnect the electrical connections and the inlet and drain hoses. DO NOT remove the hose from the bottom of the wash tub. Disconnect all hoses from the pump only. In my past experience, this particular hose is a real bear to get back on. You may not have to do all this. I include these instructions, however, because some of the small front loaders do not have a clean out trap on the drain pump. I hope this helps you. Let me know if you have further questions.
Sep 03, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
418 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
