Hi I Have A Mitsubishi DLP 65" The Problem That We Had is that All The Input including Channel 3 But there is Only One Input That is Working Do You Know Is There Away To Reset the The T.V.
    Guru:
  • 374 Answers
Hello
Can I get the model number by any chance so I can get the reset information for the model??
Posted on Apr 29, 2010
Third time replacing 65" mitsubishi dlp bulb ?
Use Osram or Phillips bulbs
Check for blocked air flow
Always allow TV to complete cool down with plug in wall
Check/Replace ballast
Aug 22, 2016 | Mitsubishi WD-65638 65" DLP HDTV
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Mitsubishi tv 65 dlp chip
If you want to buy it, contact the authorized service center for Mitsubishi.
May 12, 2013 | Mitsubishi WD65737 65" DLP TV
White dots on screen even when i turn the channel
for model listed I SUSPECT the optical light engine.
Mar 31, 2012 | Mitsubishi WD-65638 65" DLP HDTV
Video on 65 inch Mitsubishi Tv model WD-65638 is not working how may i reset this or even fix the situation.
If you have the original working Mitsubishi remote you can try a soft restart:
Menu, 1,2,3, enter
SD TECH
Aug 31, 2011 | Mitsubishi WD-65638 65" DLP HDTV
BULB IS BLOWN ON THE MITSUBISHI WD65733
your model uses the Mitsubishi 915061010 Lamp assembly with housing which is available from www.tvrepairworld.com under the Mitsubishi DLP Lamp category. The lamp comes with installation instructions and is a simple plug in , It includes the housing so you dont need to remove the old bulb from your housing to reuse since the new lamp already has the housing with it.
Aug 22, 2011 | Mitsubishi WD-65733 65" HDTV
I have a mitsubishi 65"
its auto sensing optimal format from the input used u can try to go into your settings to force it full screen possibly with remote
Nov 17, 2010 | Mitsubishi WD-65738 DLP TV
I have a 57" mitsubishi 1080 dlp tv and it has a white dot on the picturewhat is it and how to fix it.thanks terry
If the dot is there whatever the image source / input are you using then the defect is in the DLP panel - the mirrors from the panel corresponding that dot aren't commanded anymore. It can't be fixed, the panel must be replaced. It will be expensive.
Feb 18, 2010 | Mitsubishi WD-65731 65" HDTV
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Mitsubishi DLP 65 in half of screen is tinted yellow - 3 mth old
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 26, 2017 | Mitsubishi WS-65857 65" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
