Question about Nikon D90 Digital Camera with 18-105mm lens
Nikon Memory card cover has broken and needs replacing
Where can I find a replacement memory card cover that has snapped for a Nikon D90?
  • 8 Answers
Try Teleplan Camera Repair (http://teleplancamerarepair.com)
They have parts and will have no problem getting you a replacement cover!
Posted on Apr 29, 2010
Nikon d90 dslr camera
hello, always update the firmware through memory card, and not through usb cable this may be error message may not come, in case you are already using a memory card, format a new card and ensure that nothing other than the firmware is there hope this helps
thanks and regards
from v.g.chimalgi
Nov 14, 2013 | Nikon D90 Digital Camera with 18-105mm...
Memory Card Indicator always blinks
Since a couple of months, my "out of warranty" D90 is having a problem.
Even after shutting down the unit , sometimes (post of the time) the green led is blinking (at random speed) untill the battery is 100% down (after half a day).
Switching memory card , or formatting memory card does not help.
Even without lens , problem occurs.
I tried also a other battery pack , same problem...
Anyone has an possible reason why this happens , or a 100% working solution.
PS: D90, battery packs and charger are 100% genuine NIKON.
Regards, Rik
Dec 22, 2012 | Nikon DSLR D90 Digital Camera
Nikon D90 flashing green light runs down battery even in power off mode.
Possible short to the top cover circuit around and including the on/off switch - spillage, wear of switch.
Apr 06, 2012 | Nikon D90 Digital Camera with 18-105mm...
Message - E - nikon d90. How to fix it?
This indicates the lack of a memory card, or else the installed card is faulty. Remove the memory card (if present), put in a new one, and format it.
Oct 28, 2011 | Nikon D90 Digital Camera with 18-105mm...
Blinking green led even D90 is off
I couldn't find a reference to a blinking green led when the d90 is off.
I would refer you to Nikon tech support for this one.
http://imaging.nikon.com/products/imaging/worldwide/index.htm
The above link has 1-800 numbers for Nikon.
Jul 23, 2010 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 and memory card counter
There doesn't seem to be a problem. The 3.7k means 3700, the k meaning thousand. If you were to take about 2700 pictures, you'll then see 999, then 998, and so on.
Apr 07, 2010 | Nikon D90 Digital Camera with 18-105mm...
Why is it my memory card indicator light on my Nikon D90 keep flashing when i switch off my camera???? which caused my battery to run out all the time??
The memory card indicator light flashing indicates that data is being written to the memory card. At he bottom of page 29 of the User Manual it states.
DO NOT remove battery or disconnect power source while the lamp is lit. Failure to do so could result in DAMAGE TO THE CARD.
REFER TO PAGE 29 & 39 of the USER Manual for further details.
You may possibly have a fault with the camera and it is this that is causing the battery to drain, this needs to referred to a qualified Nikon Service Centre
Mar 03, 2010 | Nikon DSLR D90 Digital Camera
My d90 will not accecept the memory card
the spring loaded receiver is probably broken, take it in to a camera repair store and cross your fingers.
Nov 01, 2009 | Nikon D90 Digital Camera with 18-105mm...
We are wondering how to transfer photos from our d90 nikon camera to our computor
You need to use a memory card reader that is compatible with a SD card that is being used with your camera
Aug 21, 2009 | Nikon D90 Digital Camera with 18-105mm...
D90: Can't remove memory card.
This will need to be returned to a camera store. A jammed card can cause permanent damage to the camera as well as the card.
Mar 20, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 Digital Camera with 18-105mm lens Logo
219 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
