Question about TDK veloCD CD-RW Burner
CD Burner doesnt see a Disc is in already
My TDK VeloCD 401248 doesnt recognize a CD is in it already & asks "Put a CD in please", when one is in fact in already
  • 6 more comments
  • captainblood Mar 25, 2008
    I have used a lens cleaner as has been suggested, no change. I have been told to get new firmware & TDK is of no help. I'm stuck
    My PC is a Dell using Win XP
    Device manager says drivers good, everything fine...is it a liar?
    I will try thse suggestions tomorrow & get back, thanks
  • captainblood Mar 26, 2008
    Nothing worked, its going into the garbage. Thanks for trying
    Nothing works it going into the garbage
    Nothing works its going into the garbage
    Your Right time for a new drive, nothing works, adios TDK.
  • 4,889 Answers
Well the simplest think you can do at the moment is to uninstall the current drivers.. Then run the add new hardware wizard to detect it again. Once detected close the add hardwarewizard and go back to device manager. Right-click on your cd writer and click on update driver.. This would let windows find the best possible drivers that are available for your drive and install them.. Hope this helps.
Sai.
Posted on Mar 25, 2008
  • eagle338
    eagle338 Mar 25, 2008
    To uninstall the device drivers.. open device manager->right click on your CD-Writer and click uninstall..
  • 818 Answers
In order to write at 8, 12, 16, 24, 32 or 40x speed, you must use certified CD media. The certified media means that it is guaranteed to be able to be written to at the designated speed. It is not necessary to use certified CD media for writing at slower speeds than your drive is capable of.
Why is my drive performing poorly when it comes to writing CDs?
Possible causes:
  • IDE controller chipset driver needs to be updated
  • DMA is not enabled
  • VeloCD drive jumper is not set to Master
Possible solutions:
  • Visit your PC manufacturer's Internet website to download the latest driver for your IDE controller chipset
  • Enable DMA for all drives, including the veloCD, hard drive, CD-ROM drive etc.
  • Ensure that your veloCD drive is set to Master on the secondary IDE channel
  • 3 more comments
  • Sergio Scalfaro
    Sergio Scalfaro Mar 25, 2008
    you find support here.
    Sergio
  • Sergio Scalfaro
    i miss the linkhttp://www.tdk-media.com/consumer/suppor...
    sorry, you can find the driver to upgrade your firmware.
    Sergio
  • Sergio Scalfaro
    What do I do if my recordable CD is defective?
    Problems
    with optical media can occur for a multitude of reasons. Although we
    encourage our customers to return product that appears to be
    troublesome, a thorough analysis of the product must be conducted
    before a product evaluation can be deduced.
    Consumer CD-R/RW discs:
    • Consumer
      CD-Rs and CD-RWs come with a limited lifetime warranty, which we offer
      due to the high quality and reliability of our media products. TDK Life
      on Record makes every effort to check each batch of products that we
      produce.
    • A
      TDK Life on Record product that is defective in materials and
      workmanship will be replaced free of charge when it is returned to TDK
    • If we find that the product is non-defective in materials and/or workmanship, then they will be returned to you
    • Before sending your recordable CDs to TDK, please make sure the firmware
      on the CD burner and the recording software is updated. Often a CD
      burner needs to be updated to be compatible with newer CD-R media.
      Updating is done via upgrading the firmware. Please contact the
      manufacturer of your burner for further assistance.
    • Also,
      if you're using an older, slower speed CD burner, we suggest purchasing
      the lowest speed media available. Conversely, if you are using a newer,
      faster CD burner, we suggest using higher speed CD-Rs.
    Recording to High Speed CD-RW Media:
    • To determine if your CD burner can record to high speed CD-RW media, check the bezel (faceplate) of your recorder
    • If the words “High Speed” are printed on the bezel, then you will be able to record onto high speed CD-RW media.
    • If the words “High Speed” are not printed on the bezel, then you will only be able to record low speed CD-RW media.
    • Typically, the model number of the drive can also give you an indication if the recorder can record to high speed CD-RW media.
      • Ex: 12/10/32
        In this example, the 12 is the write speed (up to 12x w/CD-R discs),
        the 10 is the rewrite speed (up to 10x w/ High Speed CD-RW discs), and
        the 32 is the read speed (32x read back w/CD-ROM discs, Commercial CDs,
        etc).
    If
    you determine that your recordable CD is defective due to materials and
    workmanship, simply return your disc(s) to the address below. Please do
    not use tape or any other adhesive material when packaging the CDs:
    Warranty Replacement Dept.
    Suite 101, Dock E2
    8680 Swinnea Road
    Southaven, MS 38671
  • Sergio Scalfaro
    Most Dell models use
    Cable Select cables and jumper settings.
    When configuring your drive, make sure you are using Dell’s original
    IDE cable and set the
    drive jumper to Cable Select.
  • Sergio Scalfaro
    Sergio Scalfaro Mar 26, 2008
    you can send it with warranty for replace?
    Sergio
  • 1,006 Answers
Try to install driver and install it again...Let me know if u got help?
    Genius:
  • 3,587 Answers
Ok..sounds like maybe your cd drivers are kaput...what computer are you using?
  • Patrick Michaels
    Patrick Michaels Mar 25, 2008
    dell a liar..naaaaaaaaaahh...it's a simple h/w failure..get a new drive
  • Patrick Michaels
    Patrick Michaels Mar 26, 2008
    good thinking..and thankya for using fixya...I'm sure you'll review all the notes here, and accord someone with the blessing of dinero, right?
Need user manual
Go to support on the TDK website. Select your model number and download an owners manual.
murf427
Aug 02, 2012 | TDK veloCD UE-401248 (UE-401248) CD-RW...
I have a Tdk burner worked fine until my husband had his buddy install some other burning software now my burner doesn't read there's a cd in it and it keeps opening up...still looking for original tdk...
Installing different burning software should not really affect reading capabilities of the burner. Nevertheless, it is not recommended to have two burning software packages on the same computer.
You can try uninstalling the new software that was installed on your computer, the reboot the system and check if that worked. If Windows does not open the disc automatically, you can go to My Computer and access the disc by double clicking on the TDK drive.
If you continue to have the same problems, please make sure the DVD burner is connected properly to the computer.
Aug 21, 2010 | TDK (aid+420blkb) Burner
Drive light flashes and door will not open
Try to insert a pin in the small hole and it will open up. The door is probably jam and doing this will open it.
Jul 02, 2010 | TDK veloCD CD-RW Burner
My dvd burner wont burn dvd's it says insert a blank disc and it is already in the burner
try 3 things. ONE AT A TIME. #1 change your burn speed to a slower setting some dvd's will not burn as fast as they say on box.
#2.update firm ware for burner go to manufacturer's web site for your brand of dvds being used.
#3 change brand of DVD used. there are 3 major manufactures for almost all dvds and cd. The people who make disc for Sony and the other 2 companies that make everybody elses. (ie TDK,Memorex, etc....)
Oct 06, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
TDK / Velocd Burner / CDRW 5200B
I'd try cleaning the Drive with a Cleaning CD preferably a wet and dry one and maybe washing the CD surface with a little detergent and drying with a lint-free cloth wiping from the inside to the outer edge. Then reload the disk and Try reading it.
Apr 06, 2008 | Computers & Internet
failure my friend. try to restart your computer, this way, after restarting, your drive will recognize that a cd is in.
if it still doesnt recognize that a cd is in, try updating the firmware of your drive and clean the lenms of your cdrom too.
Mar 22, 2008 | TDK ( ue401248bx) CD-RW Burner
TDK Cyclone Combo
What wonnt work? does it read CD's?
Mar 19, 2008 | TDK Indi DVD 420N (AID+420N) DVD+RW Burner
TDK veloCD CD-RW Burner Logo
80 people viewed this question
Top TDK Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a TDK Computer and Internet Expert? Answer questions, earn points and help others
