Question about Konica Minolta DiALTA CF910 Copier
Konica 7022 copier error appears "call service F-26-1"
Ran out of toner on konica 7022 copier about 3 months ago. copier displayed "call service F-26-1". Finally replaced empty toner cartrige with new. Same error code displays.
  • 5,081 Answers
Your TCR sensor is dirty. Your need to take out your process unit( drum unit) and vavuum waste toner out of the hopper, and clean the TCR sensor. this will fix your problem. first remove the developer unit one screw, than the drum unit one screw. place the drum unit on the copier w/the drum facing up. remove charge wire asy, drum shaft, and bearing, than the drum, remove the cleaning blade asy. you'll see the excess toner, vacuum all out. clean the tcr sensor, locate in the middle lower part of unit, under the drum. this should fix your problem.. lots of work though... good luck
Posted on May 26, 2010
  • 3 more comments
  • sales11622 May 28, 2010
    Did everything per your Solution #1 Insructions "Call Service F-26-1" still displays.
  • INDIRA KUMAR
    INDIRA KUMAR May 28, 2010
    Then TCR must be faulty and you must replace it.
  • sales11622 Jun 03, 2010
    Looks like what I believe is the TCR sensor is part of a circuit board. Replace whole board with TCR?
    Where do I purchase? How much $$? What does TCR stand for anyway?
  • INDIRA KUMAR
    INDIRA KUMAR Jun 04, 2010
    It is an temperatute sensor which adjusts the image positioning of your copier...
  • INDIRA KUMAR
    You can just replace the TCR sensor alone..Please specify where do you live at so that i can ive the nearest location on where you can buy it...
My konica 7022 display on the screen f28-1 just today...how to fix it tnx.
Visual check the Charging corona Unit rear & front block look for burned cousing F28-1, then replaced Charging corona U.
Feb 13, 2015 | Konica Office Equipment & Supplies
Error code F 26-3 on Konica 7022
Sir/mam, you might have a bad drum density sensor or it was not cleaned or was destroyed by static electricity, if a vacuum cleaner was use to remove the old developer, NEVER use a vacuum cleaner for that procedure. Remove the drum and will see a small sensor near where the cleaning blade sits need to clean it replace it. Worse case the main control board is bad that what sensor talks to .Was the L Detect procedure run after the developer was replaced, and before you replaced the developer did you clear the developer counter, to let machine know it has new developer, because clearing the counter is the only way the copier has new developer, did you clear the counter for the new drum? The machine use the counters to determine voltages for certain assemblies. If L detect was not run and copies or prints where made get new developer and start over.
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
Konica coppier 7035 (F-26-1 error)
Since im from Phil. =) F-26-1 mean Developing problem. Check if theres enough developer (black powder) coz sometimes it spills if ok, Go to TECH. REP. MODE screen and press ATDC ADJ. wait for 2 mins. it automatically stop it will indicate OK. Turn Off the power and On.
Jan 17, 2010 | Konica 7075 All-In-One Laser Printer
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Konica Minolta Copiers
F26 Toner density adjustment problem. This means machine is undertoned. To repair, replace developer and enter "47" mode. Press 51. Press print. Allow the machine to cycle until it stops. Some feel that you should disconnect the toner motor first. This ??? ?????? happens probably because either machine wasn't set up properly, or the customer kept on using the machine with the toner light on.
Aug 22, 2008 | Konica Minolta Office Equipment & Supplies
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
Konica Minolta DiALTA CF910 Copier Logo
1,046 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
