Question about Fujitsu Plasmavision 42" TV
I have a fujitsu 42" pds4229e-b and trying to set my wii up on it but when useing the video component conections i can only get a black & white picture and no sound any ideas?? i don't have a remote at the moment.
  • 32 Answers
Have you got component cables specially for the wii? if so, then the screen should work fine.
As for audio. You'll need to use separate RCA's Red and white into the audio input if your using external speakers, if your using a surround sound amp then put them into the input there.
Posted on May 25, 2010
Wii in black and white
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
Conecting Wii to a Phillips lcd tv. rwy cords. but the picture is in black & white ?? i have sound. tried different connections eg: red to green conections & the only one that works is still black...
it sounds like you may be trying to plug a standard composit video cable (yellow) into a component video input (red, green, and blue)
these are actually two different connections. Most LCD tv's will have both options (sometimes there in weird different spots on the tv tho) if you don't have a standard RGB (red, white, and yellow composite video input) then you may need to purchase a component cable either at a local store or you can get one for $5 on Ebay
hope it helps!
~good luck!
Mar 16, 2011 | Nintendo Wii Console
I have hooked my wii up to a new samsung 42"
Make sure that you have switched the Wii to component video in the system setting menus. Once you have done that, you should have a color picture in 480p! Hope this helps!
Feb 27, 2011 | Nintendo Wii Console
Wii game hooked up to new Sharp LED tv. TV is color and the wii is in black and white.
Usually this is either a cable or a mode issue. First make sure that you have the correct cable connections. (Composite video cable to a component video jack is one possible cause of the problem.) Component video cables are not included with the set but will give better results. However, composite video in from the wii's composite video out should give good results.
If you are using HDMI or component video cables, then go into the Wii video menus to select the correct mode for your tv. Check your TV manual and the Wii setup guide for details on the mode (resolution, etc) you should be using.
If the problem persists, try new video cables and make sure that they are fully seated on both sides. Try switching inputs if you have several available.
I hope this helps.
Jan 22, 2011 | Nintendo Wii Console
I've got a LG 42 inch HDTV model GP-DVB-EU When I
When you have just the cables as you describe, you are using composite inputs. By default, yellow is video, red is right audio, and white is left audio.
Nov 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Only black and white on fujitsu 42" monitor with s-video
You need to check the Format, either NTSC or PAL, USA = NTSC, Europe etc, PAL. Set this correctly.
Mar 05, 2010 | Fujitsu Plasmavision 42" TV
Black & White Picture in different input modes
Can you describe the connections please? I suspect that the DVD +/or WII is outputing component video and you have it connnected to composite video. Please diagram the conenctions.
Thanks,
Dan
Aug 21, 2009 | Televison & Video
How do i set up my nintendo wii to a fujistu plasmavision
http://www.plasmavision.com/Plasma_PDF/OMP50XHA(42VHHA)Home.pdf this is the users manual for your componant under usage refer to connecting external equipment to display thanks for stopping bye at fixya!
Jan 01, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Black and White Video - Wii Component cable
put yellow in video red and white in audio and change source to av
Aug 16, 2007 | Nintendo Wii Console
Fujitsu Plasmavision 42" TV Logo
320 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
