Question about Kenmore Elite HE4 Electric Dryer
Kenmore he4 front load washer
Code f11 comes up almost all the time and then u hit machine on top and restart,problem ocurs mostly when in spin mode.I`ve checked conections etc. called sears and waited a week for a response, but needing the machine for approx. 3 loads a day we just keep hitting it
    President:
  • Kenmore Master
  • 2,651 Answers
F11 is a communication issue between the 2 control units and wired through and latch assy. most common i find to be is the machine controller, up under the main top of unit, check all your wires!!!!!depending on board can either be 150 , or for the top of line model the part retails for close to 300 and thats just for the part let alone the service and labor
Posted on Mar 25, 2008
SOURCE:
Whash machine
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Feb 04, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
Thanks
Aug 19, 2011 | Kenmore Front Load Washer
Washer won't spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 14, 2011 | Kenmore Elite HE4 Electric Dryer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is [email protected] live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
F11
The F11 code is from a communication break in the serial link from the CCU to the MCU (from the brains to the washer motor controller). Stay with me here!
There are three blue wires that go to the MCU from the CCU. Most of the problems probably occur during the final spin when the machine spins fastest and longest to extract all of the water.
Hence, the most vibrations cause the connectors to shake until there is a break in communication!
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 4756 n21 error code
N 21? If this is in the twenties then a drain or water issue is present. Looks like a he4 model so try this hit drain/spin and on spin speed select no spin, finally press prewash quickly two or three times. A C:0 will appear and the machine will self test. The tech manual is behind the kick panel on the bottom secured with either a 1/4 or 9/32 hex screw, then look right at the side panel for a pouch for the paper.
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
HELP!!
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
54 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
