Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Auto does not work right.
When our Mastercool is set to Auto the fan cage motor will switch to on,off,on,off,on,off. I push the Auto button off and just run the fan.
Is there something I could check or replace myself?
  • 86 Answers
1. remote problem
2 change by new one.
Posted on Mar 28, 2008
SOURCE:
Air switch not starting pump
well, the eyeball and cage assembly you refer to here has nothing to do with the pump turning on and off.
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Feb 11, 2014 | Balboa HydroAir Magna Series Spa Eyeball...
Motor only runs when i hold down the test button
test button bypasses t-stat or selector switch check those to be sure there is a call for the fan.
Aug 31, 2012 | Mastercool 67680 Evaporative Cooler Air...
Changing squirrel cage GE window a/c
yes, most smaller window units have both outdoor and indoor cages connected to a single motor in the middle of the 2 blower wheels and are completely seperate from the compressor and it associated parts
Jun 11, 2012 | Mastercool 67680 Evaporative Cooler Air...
Replacing fan motor and squirrel cage and now fan runs all the time even on auto setting
Check your wiring and also look inside the air handler for a switch that puts the fan in run.
May 05, 2010 | Goodman Heating & Cooling
Loud rumbling noise in mastercool a/c
could be the fan is full off dust or something causing it to be out of balance
May 19, 2009 | Mastercool 67471 Evaporative Cooler Air...
Squirrel cage installation.
If there is strong air flow blowing into the house the sq. cage should be OK. Possibly you need to replace the pads and make sure that the pump is not clogged and is distributing enough water to keep the pads wet.
May 05, 2009 | Mastercool 67680 Evaporative Cooler Air...
Noise on mastercool
had the same symptoms and found that tightening the squirrel cage set screws eliminated the noise.
May 23, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
168 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Paul
Paul
acrman404a
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
