Question about ASUS P5P800-VM Motherboard
Chassis intrusion messagen
When booting, I gett Chassis inrusion error message - system halted. How do I recover
    President:
  • 1,851 Answers
This means that either the case of the desktop is open or it is not closed properly. I don't know what kind of case you use so I can't be more specific. Try to close the case (open and close again) or check for an open side. If you are sure that the case is closed and still the alarm exists, there is a way to bypass that kind of alarm, but youhave to edit the bios settings.
In case of a problem or clarification or if you want to bypass the alarm from the bios, don't hesitate to post me a reply.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Apr 29, 2010
Chassis intruded fatal error system halted what can i do ro resolve it
Do you have the door on your computer case off? Just put it back on or go through your BIOS and find "halt on chassis intrusion" or something of that nature.
Mar 03, 2014 | ASUS P5V800-MX Motherboard
I am getting a chassis intruded system halted error when i start up my computer. I already check the net for possible solutions and most said it might be on the intrusion jumper on my MOBO but it seems...
While I am not familiar with your specific board, I think it's from an HP desktop system. In many systems there is a BIOS setting which controls the intrusion chassis setting. If you enter the BIOS (usually F1, esc, or DEL) look under the security tab or group. You can safely disable this and it will stop showing messages on this setting.
Chassis intrusion controls a sensor in the PC which detects if the side panel is opened. It is seldom used on computers these days, and is a passive control mostly to prevent theft of components, etc. but does not really offer any other security due to the nature of notifications (during bootup, or can also send administrative messages)
Sep 26, 2011 | Computers & Internet
I get this Chassis Intrusion Signal and the system halts... I just dusted off the fans, the jumper on the chassis signal is in default position... Don't know what to do...
You may want to check to have good closed the chassis of the computer. Some of the pcs have intrusion system detection and if the chassis is not correctly closed you get that message
Aug 21, 2011 | ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/...
Hello, i'am italian a don't speak english correctly i'have a problem my motherboard asus p5p800 vm have one error I gett Chassis inrusion error message - system halted THE SOLUTION? TANKS!
Go to the BIOS. Just restart your computer and while restarting, keep on pressing "f2" key or the "del" key, sometimes "f8" until you see the option that you can go to setup/bios. On the Bios menu, just find there the option to disable the Chassis Intrusion detection.
Oct 07, 2010 | ASUS P5P800-VM Motherboard
Chassis intruded... fatal error.. system halt..
If your case is not setup for chassis intrusion, the motherboard has dropped a jumper.
The location is by the last PCI slot between the CD audio connector and the USB bus plug. (it is right next to the CLRTC jumpers)
Good luck
Jul 21, 2010 | ASUS P5KPL-AM SE Motherboard
Chassis intruded
Can you access the bios? You should disable Chassis intrusion, I don't really see anyone needing it if it's just a home pc.
Jul 08, 2009 | ASUS P4P800-E DELUXE ULTRA ATA133...
Chassis intrusion
You need to check the chassis intrusion pin setting located on the motherboard. See page 1-30 (Number 11) in your manual.
You need to add a jumper as shown.
The system should no longer halt.
Cheers!
Mike
May 04, 2009 | ASUS P5V800-MX Motherboard
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Pc halted
very simple shut down computer put side panel back on and restart go into bios and under the settings somewhere you will see enable chassis intrusion. Just disable that. If you put cover back on then proceeded by turning power on and you still get this error than it is time to clear CMOS and then you must go into the bios and hit setup default and then go into any timings and voltage settings for CPU Memory and such. and also disable the chassis intrusion. You can enable it at anytime. just as long it is not powered up when removing side panel. I hope this is helpful.
Feb 22, 2009 | ASUS P4P800-E DELUXE ULTRA ATA133...
Error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Nov 26, 2008 | Computers & Internet
ASUS P5P800-VM Motherboard Logo
300 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
