Question about Whirlpool Duet GHW9150P Front Load Washer
Small dark circles on laundry after washing
My whirlpool duet sport washer leaves small dark circles all over my laundry. The size of the spots are the same size as the holes in the drum. I have cleaned the washer several times and feel like I'm wasting more water than if I had never given up my top load washer. Whirlpool is not interested in my problem with their product so I'm looking for any suggestions what to do.
  • Saabdog7 Jul 04, 2008
    when I wash my sheets or towels it looks like they were bleached and I did not use any bleach. the color has come out of the towels and the sheets
  • yggep Sep 04, 2008
    I have also experienced what looks like bleached spots on towels and bath rugs. This washer has probably ruined $300 in new towels! Does anyone know why this happens? I stopped using liquid bleach and my new towels are still discoloring.
    Sergeant:
  • 351 Answers
If you do cold to warm washs all the time you will get sludge between the drums,try several 95 degree washs with no cloths in it and see how you go .hope this helps.do you use fabric softner.
Posted on Mar 26, 2008
How to remove filter on Whirlpool duet sport front loading washer
Whirlpool Duet Washer is a front-loading washing machine.
  1. Remove the lower kick plate. Unscrew the two screws holding the kick plate in place, and gently pull off to remove. ...
  2. Place a small bucket under the white hose. ...
  3. Look inside the white hose. ...
  4. Look inside the hose cap. ...
  5. Twist the cap back onto the white hose.
How to remove filter on Whirlpool duet Google Search
Jan 02, 2018 | Whirlpool Washing Machines
Why do Whirlpool Duet washers have such a problem with "over sudsing"? And how to prevent it?
The "oversudsing" problem is usually due to operator error. These new front loaders require the use of HE laundry detergents. These greatly reduce the sudsing issue. They also require VERY LITTLE detergent. For example, a normal-size laundry load only requires 1-2 TEASPOONS of HE laundry detergent. Most folks use much more than that, causing a possibility of oversudsing.
See this link for more info.
What Is HE Laundry Detergent And Do You Need It
Aug 08, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
We have a duet sport ht, it seems to leaving greasy/oily spots on our clothes? any idea/cause? thanks
Be sure to use the quantity of wash powder recommended on the packet and not less. This will help keep the clothes AND machine clean.
Mar 23, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Dark spots on my clean clothes
do you use a lot of fabric softner? If you do this might be your problem try to change soaps and stop useing fabric softner. try useing powder detergent and make sure that it is HE. let me know how it goes thanks
Jun 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
May 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
235 people viewed this question
Dan Webster
Dan Webster
Sal De
