Question about Singer Quantum 9940 Computerized Sewing Machine
Won't pick up bobbin thread - Singer Quantum 9940 Computerized Sewing Machine
    Genius:
  • 1,116 Answers
Refer to your manual to be sure the needle and bobbin are installed correctly.
If the needle is in wrong, the thread will not guide down the groove on the needle shaft and through the eye as it should in order to form stitches with the bobbin thread.
Posted on Apr 29, 2010
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Feb 06, 2016 | Sewing Machines
The bobbin thread won't pick up
this is all i can find out for you so not sure if this will help you out.
If it is not in the correct position, the needle will not go down and pick-up your bobbin thread. ... Also, make sure your bobbin is in correctly (not backwards) and that the upper tension disks of your machine arethreaded correctly. Make sure the presser foot is upwhen seating the thread through the upper tension.
Frequently Asked Questions ' Singer Sewing
www.singerco.com/support/frequently-asked-questions..
or go to this link might help you..
janome sewing machine won pick up bobbin thread Google Search
Oct 29, 2017 | Janome Sewing Machines
JUKI BOBBIN THREAD WILL NOT FEED
Most machines require that the bobbin in the case unspool in a certain direction its considered common knowledge I guess because it doesn't seem to be written in the text of manuals... but is indicated in the photos. make sure it's unspooling correctly.
Secondly. Please make sure you have the correct needle for your machine. Some machines do not use a 15x1 (most common needle) Let me show you. (see photo below) Clearly the 241x1 won't fit into your machine. BUT the 15x1 will go into the machine that requires the 20x1.... and the result is it won't pick up the bobbin thread.
Start there. Then check your timing.
Sep 05, 2012 | Sewing Machines
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
Won't pick bobbin thread up
If you have changed the needle and made sure it is in the correct way round you may have to retome the machine
Aug 04, 2011 | Singer Sewing Machines
Singer Quantum 9940 Computerized Sewing Machine Logo
95 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
