Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
I love the radio and I hate to have to replace it. It works great but I can no longer use the side wheel to make menu selections. I can push it to select but turning it does nothing. I openned it and found that the wheel had come loose and it looks like it is no longer engaging in the detents on the track. Is this repairable? Are there parts available?
  • Delphi Expert
  • 509 Answers
It is a difficult to replace surface mount part. You are stuck with using a remote control for the 'roller dial' function I'm sorry to say. Or buy one on eBay that works and transfer your subscription.
Posted on May 27, 2010
Can the front wheels be locked
I just Fixed this problem today with the bike Radio Flyer Trike 4 in 1. I just opened the red adjustable hub, and found one spring detached, and both springs that control the 2-pawl system of ratchet system very loose. I tensioned both springs but it worked for one day only. Called customer service, provided all the necessary information and they promised a new front wheel.
In 3 business days a received, a brand new front wheel with pedals and fork. The pedals are fixed on wheel, and is the best solution from radio Flyer for a Kid who is grown with the bike from 18 months to 36 month, and now at age 3 rides the lovely Radio Flyer like a dare devil. Thank you Radio Flyer.
Having a strong mechanical background, I opened system, both sides of the wheel. To dissemble and repair, I had to remove one pedal on the side of the big white hub. What I found inside was a Ratchet wheel, with rounded teeth, and 2 Pawls totally worn out.
I fixed drilling 4 holes all the way through metallic plate, ratchet wheel, and the hub of the wheel. Inside the hub cavity, I used 4 washers and nuts to secure tight all 4, 3/32 stainless steel screws.
My grandson is very happy and more confident, because now he can move the bike forward, and backwards, and the most important, now he can use the pedals of the front wheel to stop the bike. Which it was a safety flaw by original design of this bike, but solved now by Radio Flyer. The new wheel Red Hub has 2 Positions. 1 PULL TO COAST. 2 PUSH TO PEDAL.
Jul 22, 2014 | Radio Flyer Steer and Stroll Deluxe Trike
WS-65611 PIP worked until cable tech connected new Digital Box
do u want pip form the cable box itself or watch dvd on one side then tv on other
Jan 25, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Radio flyer 4 in 1 trike
Same thing happens today with the bike Radio Flyer Trike 4 in 1. I just opened the red adjustable hub, and found one spring detached, and both springs that control the 2-pawl system of ratchet system very loose. I tensioned both springs but it worked for one day only. Called customer service, provided all the necessary information and they promised a new front wheel.
May 26, 2014 | Radio Flyer Steer and Stroll Deluxe Trike
How do i set the clock on my yamaha v star 1300
Turn key to on, hold select switch up for 10 seconds, and hold reset switch for 5 seconds while continuing to hold select switch. Hours should be flashing. Push select switch down to change hour. Push reset switch to select minutes. Push reset switch to finish.
God Bless and ride safe :-)
Oct 14, 2011 | 2007 Yamaha V Star 1300
Got moniter working but screen is too wide for monitor i have to usw cross arrows to read the whole page
Each monitor has settings buttons on the front or side of the monitor to set the screen size, brightness, etc. Look for a button or wheel and find the menu, then go find the screen sizing, but verticle and horizontal and move it so it fits the monitor screen.
Pushing buttons on the monitor will not cause any damage, so try then all until you find the menu button and then you will need to find the button or wheel that moves you from selection to selection. Generally, pushing the menu button will select the highlighted menu item so you can adjust the settings.
I hope this was helpful.
Brian
Dec 24, 2010 | Computers & Internet
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
Baby trend expedition double jogging stroller
No but if you just sort of push on one side of the handle bar it will pull it to turn without lifting the front.
Aug 25, 2008 | Baby Trend Expedition Double Jogger
Combi Stroller - Can front wheels be replaced?
We loved our combi at first, but now both wheels are bad. We used to recommend the stroller because of it being so compact, but HATE the wheels. They should recall them or at least revise them.
Apr 16, 2008 | Combi Travel Savvy Stroller
?Remote test? on screen
You have to reset the device: 1. Lock and then unlock the IPOD using the Hold button. 2. continually press both the Menu and Select buttons at the same time until the apple logo shows up(this should take 6-10 seconds). You might have to repeat the step several times. If running into problems during resetting place the device on a flat surface and make sure that while pressing Select you?re not touching the touch wheel, and that you?re pressing Menu on the outer part of the wheel and not towards the center. If that didn?t work try connecting it to a wall electricity socket or the PC and see if it effects the situation in any way. Good Luck
Feb 21, 2006 | Apple iPod mini M9160LL/A MP3 Player
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
100 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
