Question about Destroyit 2603 Shredder
Motor turns on , but will not shred the paper
  • 86 Answers
How old is this machine? I'm a certified destroyit technician. If it has 1 round button there may be a few steps i can walk you through to get you back on the road.
Posted on May 12, 2010
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
I have a novitech shedder. The motor works but it will not shred?
It is probably a gear that is not longer connecting or is worn so will not turn the teeth. It is a little known fact that shredders need to be lubricated at least annually as the fine paper begins to clog the teeth over time and can over-work the motor.
Solution if this is the case - purchase a new shredder and some lubrication.
Oct 27, 2012 | Fellowes Office Equipment & Supplies
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
When I put paper to shred ,all I get is motor noise but no shred
You probably have a stripped drive gear. let me know what brand shredder you have.
May 14, 2010 | Office Equipment & Supplies
Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
Oct 23, 2009 | Royal VF1000MX Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Overly loud shredding; stops prematurely
I have taken many shredders apart and found them so clogged up with shreds of paper and too much oil will turn into paper mud.Be bold and take the top off and clean it out. Unplug the power source and when removing the top , be careful because their will be a short cable connecting the top to the circuit board. Easy to damage.
May 12, 2009 | Fellowes S701CM Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Shredding no more
if the unit is pulling paper thru but not shredding your cutters have separated for some reason. If not pulling paper thru but machine is running you probally have a broken gear causing cutters to no longer turn you may hear a clunking or grinding noise or gear may be stripped if shredder sounds like it is spinning freely. Contact manufacturer for parts availability.
Nov 26, 2007 | Royal CIA 12X Shredder
Destroyit 2603  Shredder Logo
126 people viewed this question
Top Destroyit Office Equipment & Supplies Experts
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you a Destroyit Office Equipment and Supply Expert? Answer questions, earn points and help others
