Question about Maytag 30" Self-Cleaning Freestanding Gas Range - White
How to put the door back together correctly on a Maytag Range. Model #MGR5745ADW
  • Maytag Master
  • 8,220 Answers
I lay the door on a nice work table and lay in the insulation. I attach the handle or the base first depending on the model then lay on the new outer glass and attach the handle and top or the base. Then I carefully snap the sides on last. I like to attach the bottom plate fist if at all possible then lay in the insulation and glass then attach the top plate and handle, then snap the sides on. The hardest part is getting the sides on.
Posted on Apr 29, 2010
Testimonial: "Thank you for your help."
Unlock door of maytag range model mgr7775ws
unplug the range let it sit for a while then plug it back in.
Oct 23, 2012 | Maytag MGR7775WS - 30"Self-Cleaning...
NEED A WHOLE DOOR FOR MY MAYTAG ELECTRIC RANGE MODEL #MER5750AAW
The door is not available as a entire assambly it is comprised of like 30 individual peices that make up the door, i included this parts breakdown for all the parts on the door.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Range-Parts/Model-MER5750AAW/3048/0124111/X2906094/00005?blt=06&prst=0&shdMod=MER5750AAW
Gene
Aug 03, 2011 | Maytag PER5510 Performa Electric Kitchen...
Slow to heat up
Most likely your ignitor is going bad. This is the part that glows before the gas comes on. It has to draw the proper amperage to allow the gas in the oven to light and burn. Some ignitors glow and look good but are not drawing enough amperage for the gas valve to open, with the problem you are describing.
Very fragile part, easy to break,
good luck.....
Feb 24, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
5Ab error code for a Maytag Electric Range
You may have inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
To turn the Sabbath Mode on/off on most Maytag models you simply press and hold the "Clock" button for 5 seconds. These instructions should be in your owner's manual.
If this does not correct the problem for you, please post back with your model number (located on the back of the range or around the oven door opening) so that I may be able to assist you better. I hope this helps you.
Nov 01, 2009 | Maytag MER5775Q Electric Kitchen Range
We tried to change the time on the clock of our range. However a time isn't showing but the letters and numbers 5A6. How can we correct this? Thank you
You have inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Nov 01, 2009 | Maytag 30" Self-Cleaning Freestanding...
How to install Maytag oven door for model MGR5765QDQ ?
Pull the door mount bars to the first stop--where you keep the door open to broil. Slide the door back down on the bars.
Mar 02, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
F9 error message - what does it mean and how can I fix?
If the heading you used is correct and this is a Maytag Kitchen Range, "F9" is a Door Latch Supervisory error, or a defective Electronic Range Control (ERC) board (this is the clock assembly board). Since you mentioned you are having difficulty with the door latch mechanism, I would attempt to repair or replace it first. The door latch costs around $50, while the ERC runs about $140-$150 @ repairclinic.com. Just type in your COMPLETE model number in the Search menu and there's a complete parts listing available with illustrations. They also have a service manual available (item# 893398) for about $30 that you can order to assist in repairs. Post back if you need further assistance, please. I hope this helps you.
Mar 27, 2008 | Maytag MER5770 Electric Kitchen Range
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Range lock issue
rollover, press and hold the stop time and cancel keypads together for 5 seconds. See if it comes back to life...Catriver..post back.
Apr 21, 2007 | Maytag PER5510 Performa Electric Kitchen...
Maytag 30" Self-Cleaning Freestanding Gas Range - White Logo
115 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
