Question about Air Tools & Compressors
I ,m sorry i don.t have a power tool trying to remove starter on 1994 dodge dakota manually. have one bolt off but can't get the other one loose
  • billyandpat May 03, 2010
    yes very helpfull
    yes very helpfull
  • 2,100 Answers
Do you have the correct socket on there? Fits good? How about an extension bar or a breaker bar? They torque them on there tight. Get in a good position so when it lets go, it doesn't smash your knuckles, if you don't have a breaker bar, get a piece of pipe that will fit over the handle of the ratchet. Give it a good yank or push it with your foot if you have to. A socket extension will cause the ratchet to twist, so keep it as short as possible. Good luck. Hope this helps.
Posted on Apr 29, 2010
Manual
FIND STARTER
REMOVE HOLD ON BOLTS/NUTS
REMOVE ELECTRICAL LEADS
RE-INSTALL IN REVERSE ORDER,,,MAKING SURE TO PROPERLY SHIM THE STARTER IF KIT COMES WITH SHIMS
Jul 21, 2013 | 1993 Dodge Dakota
Starter Bolt Size
you can buy them at autozone,they may even know what size you need. usually starter bolts are the same size and in some cases just the length is different. simply try the one you have in the other hole and if it works then problem solved on the size but the length may still be different.
Aug 12, 2012 | 1993 Dodge Dakota
Cannot remove starter from 1995 dodge dakota 5.2 all bolts off, will not disengage from transmission.?
Some of these also have a metal bracket at the back of the starter, if not you need a soft faced hammer and give it a solid whack near the back of the starter to loosen it from the bellhousing.
Mar 08, 2012 | 1995 Dodge Dakota
How do i change the starter on a 1990 dodge dakota
starter is on the left side of the motor
disconect the battery
raise left side of truck up
place jack stand under it
remove the 2 starter wires from the starter
remove the 2 15 mm bolts from the sterter that holeds it to the transmission
remove the starter
reverse this to install
Jul 09, 2010 | 1990 Dodge Dakota
I need to replace the starter in my 1998 dodge dakota. Anything special I need to be concerned about?
just disconnect ur battery. remove 2 starter bolts, then disconnect wires attached to starter. install in reverse order.
May 23, 2010 | 1998 Dodge Dakota
1991 Dodge Dakota truck will not turn over nothing and I also get no brake No power at all
Try cleaning the wires on the starter, disconnect the battery first, remove the two bolts on the starter, clean all corrosion and put the bolts back on, and see if the vehicle will get any power.
Oct 30, 2009 | Dodge Dakota Cars & Trucks
How to remove a starter for a dodge dakota, and does the sterring linkage have to be removed if so how?
you should be able to drop from bottom. If tire ros interfere turn steerinf to extreme left or right/
May 27, 2009 | 1987 Dodge Dakota
93 or 94 Dakota Transmission
look at the starter bolting the location on bell housing differ depending where manufac...
plus start counting splines on the shafts..
May 07, 2009 | 1994 Dodge Dakota Club Cab
Serpentine belt on 1992 dakota
You don't mention which engine you have in your '92 Dakota, but it's likely the 3.3L and if so, here's the diagram. Even if your engine is not the 3.3L the principals for replacing the belt are the same.
Get a serpentine belt tension release tool (local parts store) and use it to take the tension wheel away from the belt, which will make it loose enough to remove by simply pulling it off one of the pulleys (the alternator will be easiest) and then wiggle it out of the engine bay. The tool should come with a selection of heads for the different variations of tensioner arms/bolts. Once the belt is removed, replacing it is the reverse process.
Hope this helps, and please rate my answer.
Jan 08, 2009 | 1992 Dodge Dakota
Air Tools & Compressors Logo
69 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
