Question about LG Xenon GR500 Cell Phone
LG Xenon - saving Contacts to sim card?
I got another Xenon because my original had a huge problem with it after 4 months, and I cant figure out how to save everything to my sim card to put in my new phone... Help!
What you want to do is you click the (on the home screen) in the bottom right corner the square with four dots in it. then you click address book, after that you click Management, the fifth section from the top, then you click one of the four options *copy to SIm *Copy from SIm* Delete from SIm *Delete from phone
Posted on May 15, 2010
Go to settings and go under adress book then i think its call like set up or something click on it and it says "transfer contacts to sim" and "transfer contacts to phone "
Posted on Apr 30, 2010
How to unlock the lg xemon (instructions)?
You can Unlock the LG XENON GR500 model Phone using the Unlock code,You can get the Unlock code and instructions from here
Classicunlocking.com and Unlock it from Network Lock....
LG GR500 Xenon Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your LG GR500 Xenon mobile phones. If you enter over a certain amount of wrong unlock codes on your LG GR500 Xenon mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
Aug 03, 2011 | LG Xenon GR500 Cell Phone
How do you save contacts to sim card on the LG Xenon?
ok when ur saving acontact theres lots of fields to fill out like name number etc. the last one is an option where to save to. just figured it out haha
Apr 08, 2010 | LG Xenon GR500 Cell Phone
Delete texts saved to sim card - lg xenon
go and change to save all texts to phone then delet all texts again
Apr 05, 2010 | LG Xenon GR500 Cell Phone
Why does it show insert sim card if its already insterted?
becauyse it doesnt recognize it... clean the contacts on the sim card, and the phone, if theyre worn.. you could need a new sim card, also simcards can **** out after a couple years... mmine only took 5, might need to order a new one..
Jan 09, 2010 | LG Xenon GR500 Cell Phone
I just recently changed phones using the same sims card i had in the old phone;and know when my saved contacts call the name doesn't show it just says no name w/ph#.
You have to make sure that all the contacts in your old phone was saved to your SIM card, and then you have to move the contact info from that sim card to your new phone.
Good Luck,
Jesse
Jan 06, 2010 | LG Xenon GR500 Cell Phone
My daughter has an LG xenon, and has entered the wrong PIN1 number ten times. Now upon startup the phone says to insert SIM card, which is already in place. How can I fix this?
You'll need to get a new SIM. Contacting AT&T will get you a free one and save you $25. If you want to just get one, Walmart and RadioShack and Best Buy all sell them.
Nov 04, 2009 | LG Xenon GR500 Cell Phone
Lg xenon won't delete recent text messaging recepants
Unfortunately this is not an easy task...
I finally figured it out on my Xenon after weeks of playing with it and researching it...
1. Make sure all of your contacts in your address book are saved to your SIM card.
2. Make sure all of your photos, ringtones, etc are all saved to your Memory card.
3. Remove your memory card.
4 Go to Settings - then Phone - Then to Reset Settings.
5 Here you want to do a Master Clear. *Warning - this will take away all of your settings on your phone - and you will have to re-customize it. Choose PHONE and not memory card here. It will ask for a security code - by default, your code should be 0000.
6 Put your memory card back in and send out a "test" text to the top 5 people that you text... Those names will now appear in your Most Recent Text Recipients list.
It sucks, and it's a long process, but I can't figure out any other way.
Then you restore all of your settings manually (ringtones, picture wallpaper, etc.)
Hope that helps!!!
Jun 27, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
LG Xenon contact issue
Better late than never? When you add a contact, scroll down to the bottom and click save to sim card . I was having the same problem until I did that and it seems to be fixed.
May 17, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Contact problem LG Xenon
Under "New Contact Menu" Change the memory to SIM.
Apr 29, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
LG Xenon GR500 Cell Phone Logo
3,136 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
