Question about Dell E193FP 19" LCD Monitor
Power button is flashing and the monitor is not coming on. check all connection are fine even plugged into second computer and no differences. thanks john
    President:
  • 1,561 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Since the power led or button is on, this indicate that the picture board is not responding.
The picture board of your monitor is bad that is why your monitor is not displaying anything on the screen, it means the picture board of your monitor has developed fault, because the power button is on.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on Apr 29, 2010
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
Monitor is slow coming on then when on website clicking out of second tab flashes black
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
My scepter flat screen computer moniter keeps flashing on and off. It is hooked in correctly, however, even when the tower is off the screen flashes on, then to standby and then to just off. The whole time...
try to use the menu buttons of the display/screen to reset it to factory defaults and use the auto-adjust option if available. this often resolves common issues specific to the screen itself. it can help help to remove the power cord from the monitor then hold its power button for about 10 seconds to drain any power and test it again using another video cable. you may also want to observe if it flashes when not connected to the video cable and when plugged in to a different power outlet and cord.
Jul 18, 2013 | Computers & Internet
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Screen flashes on for around 1-2 seconds before turning off
Your TV has a defective component on the power supply section. Need service by electronics technician.
Jul 27, 2009 | Computers & Internet
When i try to turn the viewsonic on the green power button comes on for approx. 7 seconds then flashes off without any picture appearing on the screen. The red power button does not come back on until i...
This generally means the monitor can not detect a video signal. Have you tried a different monitor? Or try the monitor on a different computer.
If those are not options, check you video card and try to boot Windows in Safe Mode (VGA resolution).
Jules
Jul 24, 2009 | Computers & Internet
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Monitor won't come on
Lets start with the basics. Does the monitor have power, do you get a light on the monitor when you try to turn it on? If you do then do you get any lights on the computer when you try to turn it on? If the monitor has no lights on it check the power connections and if still no lights then try plugging it into a different outlet preferably directly into the wall. If still nothing then the monitor is bad. If the computer has no lights but the monitor does once again try plugging it in to a different outlet and if that does not work there is a problem with the computer most likely the power supply, CPU, or motherboard. If both have lights but you get no display on the monitor then check the connection between the monitor and the computer. if the connection is good (I would ***** in the screws on the sides of the connectors just to make sure there is a good connection) then there could be a problem with your video card.
Mar 12, 2008 | Computers & Internet
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Dell E193FP 19" LCD Monitor Logo
165 people viewed this question
Alun Cox
