Question about Brother MFC 240C All-In-One InkJet Printer
Printing garbage when I go to some sites like my health care provider it will print a a page ok then some garbage on part of or on the entire other page Called brother and reset internet explorer to default settings but it did not help Looks like some lines the letters print ontop f each other,then weird numbers or % sign or * sign Instead od a line the should say "Amount you may owe the provider "I get "Amount You N bz P x f Provider" Another line that should show the $ amount I owe as in $45.00 I get "76/11 or 49/11 )2*Another whole page is just pure garbage
  • 903 Answers
That sounds like a problem with the print driver. Are you using the correct driver for your operating system? Try reinstalling your print driver, or if there is a newer one available, update the driver to the newest version. You can find MFC-240C drivers here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc240c_all
Posted on Jun 04, 2010
Hp J5780 all in one - I cannot get the printer to attach to the bottom portion.
Regarding your recent inquiry about the HP 74, 75, 74XL or 75XL ink cartridge error message ("Cartridges Not Aligned" or similar printer alert condition) and inability to print with your HP OJ J578 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside one of the ink cartridges (.....it is very rare for both cartridges to fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, and to confirm/determine which of the two ink cartridges is causing the failure condition, please run the 'Tap 41' cartridge's electrical diagnostic test below (refer to C.)
Please first verify the age of the ink cartridge(s)....look at imprinted date on front of ink cartridge. If this 'warranty expiration date' has expired, then potential internal electrical cartridge failures can occur due to internal corrosion, etc.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
DIAGNOSTIC STEPS:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Print Extended Self Test:
    1.Press CANCEL + OK buttons at the same time.
    2.The extended self test page should print.
    --- Verify all colors and all stair-step nozzles are firing (i.e. no missing horizontal lines should be visible in the stair-step grid patterns). (NOTE: the self test page is a 'forced' test print whether the ink cartridges are good or bad). Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
    C.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure (or .pdf document) at the following links on how to activate and read the service test:
    http://inkjet411.com/?page_id=544
      1.Press the * and # keys simultaneously.
      2.Enter 124 (or 123) at keypad.
      3.Use the arrow keys to navigate to the System Menu. Select Ok.
      4.Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Should display 'code = 0'.
      5.Use the arrow keys to enter 'code = 41' (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern should begin to print.
      NOTE 1: The 'Tap 10' (extended self test) can also be activated by pressing CANCEL + OK buttons at the same time. Whether ink cartridges are good or not, i.e. this is a forced print test). Refer to following 4 paragraphs (or video) on how to interpret diagnostic report.....
      NOTE 2: You may also refer to this document for specific printer model 'Tap 41' diagnostic & 'Cartridge Error Bypass' step-by-step instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
      --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 75/75XL color cartridge should display 600 good nozzles, while a good HP 74/74XL black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout.
      ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
      You can also test general printer performance by running the 'Tap 10' diagnostic test, use same procedure above and enter "code = 10". Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one or both of the ink cartridges is damaged.
      NOTE 3: It is possible to 'temporarily' bypass the cartridge error message (for emergency printing purposes only), please refer to link above/below for video/documentation instructions. However, if the cartridge is determined to be electrically damaged, largely dependent on the 'Tap 41' diagnostic test results, the cartridge will eventually need to be replaced with a new one. With a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced:
      D. Cartridge Error Bypass ( Emergency Printing Only - http://inkjet411.com/?page_id=544 ):
      1. Press the * and # keys simultaneously.
      2. Enter 123 (or 124) at keypad. The 'Underware' menu should be displayed.
      3. Use the arrow keys to navigate to the Information Menu. Select Ok.
      4. Use the arrow keys to navigate to the 'checksum for relock data input'. Select Ok. LCD should display a 5-digit number after a few seconds.
      5. Attempt to send a print job to printer
      NOTE: with a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced.
      *Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. The "Incompatible Print Cartridge(s)" / "Print Cartridge(s) Problem" / "Refer to printer documentation" / "Cartridge Error: Cartridge must be replaced" / "Cartridge in left/right slot is not intended for use in this printer" / "Now printing alignment page" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also note that it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active state of both cartridges.
      For reference, the following page provides a complete review of the majority of cartridge error messages you may observe on your printer at one point or another:
      http://inkjet411.com/?page_id=509
      However, if your printer works routinely after inserting a brand new HP 74 and/or HP 75 ink cartridge in it, then this will confirm root cause of failure as being limited to one of the ink cartridges.
      For additional HP OJ5700 printer series diagnostics information please visit: http://inkjet411.com/?page_id=1813
      CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors. We do NOT suggest refilling these types of ink cartridges.....refilling of HP 74/75 original/genuine ink cartridges is only suggested!
      HP 74/75 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=WqnHRFpbo0w
      If you need to purchase a new HP 74/75 ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and provide a 1-year warranty (remanufactured ink cartridges which have been thoroughly tested; purchases are only available by USA residents).
      For any additional questions please contact us directly: Inkjet411help@gmail.com
Feb 17, 2015 | HP Officejet J5780 All-In-One InkJet...
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
Need help in fixing HP Photosmart C5280 Printer two springs on the side of carriage bar
We suggest you contact 'Parts Here' as they provide most parts for the C5280 printer, including carriage assembly parts, along with the C5280 service manual: http://www.partshere.com/models/hpprinters.asp?printer=Q8330A
C5280 CONTACT CLEANING / SERVICE TEST DIAGNOSTICS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding - refer to Inkjet411's support page: http://inkjet411.com/?page_id=1519
B. Print Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test page should print. The printed pattern will verify printer is generally functional
--- The self test page is a 'forced' test print whether the ink cartridges are good or bad. Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
C. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure or .pdf document at the following links on how to activate and read the service test report: http://inkjet411.com/?page_id=536
1. Load Letter/A4-size paper into paper feed tray.
2. If any lights are blinking, first press Cancel to attempt to clear.
3. Press and HOLD the Cancel button, press Ok button once.
4. At 'Mfg Commands' menu, click Right Arrow once until 'uiaux service' menu is displayed.
5. At 'uiaux service' menu, click the Right Arrow until Special Reports menu is displayed.
6. Select Ok, then click Right Arrow until the 'print-mech button tap' menu is displayed.
7. Select Ok (Code = 0 will be displayed); click and hold Right Arrow until 'code = 41' is displayed. Use the Left Arrow if you need to decrease numerical count.
8. Select Ok. Within one minute the Tap 41 diagnostic test report should be initiated and print (whether ink cartridges are good or not, i.e. this is a forced print test). See following 4 paragraphs (or video) on how to interpret diagnostic report.....
NOTE: If you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available for US Residents only).
-Thank you
Oct 15, 2014 | HP Photosmart C5280 Printer
Is there something like a reset button on my HP 4000 TN? It is printing garbage, and I cancel job, it seems to cancel it, but starts printing garbage again. Tried turning it off, etc.
in the print queue
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel:
hope this helps
Jul 13, 2011 | Computers & Internet
I have an hp off.jet 6310/the print-que thinks it's prinying, but it ptints 7 pages of garbage.
There's an old saying with computers-Garbage in,Garbage out.If you feel your computer is printing only garbage,do a print preview.Then you can see what the printer is going to print.This also gives you the opportunity to pick which pages you want printed.
http://www.udel.edu/topics/printlessnew/PPreview.html
Please go to this page for a walk thru of print preview.Hopefully there will be no more garbage,right?
Jan 19, 2010 | Nova Development Art Explosion Greeting...
TM88IIIR on XP machine prints garbage
Turn printer off hold down on feed button and turn it on. This will produce a test page. Compare all your settings to the port settings that it is plugged into. It sounds like a buffer problem.
Jan 14, 2010 | Epson POS TMT88IV Thermal Receipt Printer
I TRY TO PRINT ONE PAGE AND THE PRINTER PRINTS MULTIPLE PAGES AND IT IS ALL GARBAGE.
This happens when you have the wrong driver software loaded into your computer. Try printing a test page directly from the printer. Hold the 'page feed' button as you power up the printer. This will tell you if the printer is working. If this is ok, try a different print driver in your computer.
Sep 09, 2009 | Epson Stylus Color 740 InkJet Printer
Printer keeps printing garbage
i believe that if you update the firmware for the copier, you shoud see that the garbage printing should go away.
Mar 31, 2009 | Minolta DiALTA Di183 Copier
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Brother MFC 240C All-In-One InkJet Printer Logo
96 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
