Question about Refrigerators
Dometic RM1350 refrigerator Need info on adjusting the doors on your frig. The right hand two door need to be adjusted upwards. The problem is that the bottom right hand door rubs on the interior of the frig and also the travel lock on the doors of the frig will not keep the right lower door secure for travel. Needs to be adjusted up can you please help. Thanks Grant
  • 6 Answers
SOURCE: operates with gas, does not operate with AC.
Check the heater element for power.
Posted on Jul 01, 2009
SOURCE: DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
Posted on Aug 24, 2009
mgprice
  • 744 Answers
SOURCE: How do we adjust the door height on our GE Profile
Hello, Take the cover off the top hinge and then remove the top hinge and the door, the problem may be a worn hinge cam, if it is replace it. If the hinge is loose tighten the bolts. Once the door is off you will see how the lower hinge can be adjusted. Hope this helps! Mike
Posted on Dec 02, 2009
  • 153 Answers
SOURCE: The right door of my Kenmore side by side
You may have a broken cam riser which is located at bottom hinge. Compare the 2 hinges with the doors open. The right side is probably missing 1 piece.
Posted on Feb 17, 2010
rickyrt441
  • 4399 Answers
SOURCE: What does the diagnostic code "F" mean ion a
What is the number after?
Posted on Feb 26, 2011
How do I pull the refrig out from the wall so I can replace door on Dometic frig ?
Put your hand in front of the refrigerator at the bottom and just pull
Oct 25, 2017 | Dometic Refrigerators
I have a rm1350 Dometic refrigerator. The temperature seems to be creeping upwards regardless of how high I set the temperature. I think I need to replace the power module board.
see if inside sensor has fallen if ok try with thermistor disconnected if ok replace if same board or cooling unit is freezer ok
Aug 25, 2017 | Dometic Refrigerators
Dometic refrigerator troubleshooting rm 3662,
Hi, It is more then likely the heating element or a fuse in the electronic board located on the rear of the refrigerator. The heating element is located on the right hand side looking at the rear of the refrigerator. It is the probe like item that protrudes from the duct work with two black wires attached. You must disconnect the wires from the board then take the door off of the duct work, the the heating element will slide upwards to remove it. Please feel free to contact us 1-888-782-6665
ArctiCold Refrigeration We keep it cold
Aug 17, 2014 | Dometic Refrigerators
Sub Zero - 700 TCI 2 :Water is forming on bottom of Frig.
Most refrigerator doors are adjustable. You may find that adjusting the door so that there is a proper seal eliminates the water collection problem
Sep 12, 2012 | Sub-Zero 700TC Bottom Freezer Refrigerator
Freezer Door will not stay closed, opens about a half inch after removing pressure.
You can try and adjust the front legs of the frig raising the front about one or two inches. This will but more pressure on the door seal.
Sometimes if you slam the frig door the freezer door will try and open. Tilting the frig back will help solve this problem.
Dec 31, 2009 | Kenmore Refrigerators
I have a Haier Refrigerator, Model HTE18WAAWW-08. The freezer door has shifted down and the refrigerator door will not close smoothly. How do I adjust the freezer door upward to allow the refrigerator door...
Hi, this is caused sometimes by Teens and Adults holding the door open with there hand on the upper corner resting as they look for goodies, I do this. This sometimes will cause the door to loosen up and move down a wee bit. Look over the hinges on the door, they should be adjustable to see if they have moved. I am sure this is the problem. You can loosen some more, and raise or lower the door. It would be a lot better to have another set of hands to help with this.This will take care of the freezer door.Best of Luck, Sincerely,
Shastalaker7
Nov 23, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Noticable gap between door and frig ,need to bring door up
Hi: Some refrigerators had a plastic cam mounted on the bottom hinge to help the door close. The cam can break and be easily swept away. This will cause the door to lower and not close as well as it used to. I've seen GE's do this. Give me more info on the model. and I may be more help. Good luck Jeff
May 31, 2009 | Refrigerators
Refrigerator slides on floor causing door to bind
there should be some adjustable feet in the front that you can tighten down so that the wheels get pushed off the floor. causing the fridge not to move. if that is already tightened down another idea is to find out the distance from the back wall and get a piece of wood that length and just set it back to prevent the fridge from moving back. hope that helps
Jun 11, 2008 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
