Question about Kodak EasyShare Printer Dock Series 3
Does not print total picture I only get a 1 inch strip down the left side on two different printer docks after taking a panorama picture
    Scholar:
  • 118 Answers
Sounds like you need to go to the printer page, go to set up and do a printing test. this will clean the heads and set the printing format.
lastly, kodak's web site might have a trouble shooting information guide to help resolve the issues.
Posted on Apr 29, 2010
Kodak Easyshare printer prints only the left side
did you ever get it fixed? im having the same problem....
Apr 29, 2010 | Kodak EasyShare Color Photo Printer Dock
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
A940 printer stalls and gives a hardware message
This is a usual problem whit this model of printer, i had been thru this three times already.
In my case, the printer stops completely halfway printing and shows "Hardware error 502", i found that is because the optical sensor strip is dirty, first you should try to clean it with out removing it form the printer, to do this you should:
(The optical sensor strip its an nearly transparent plastic strip behind the print head, if you look closely it has very thin lines painted on it, this is used by the printer to measure the movement of the print head)
1- Print something to case the hardware error and shut it down immediately
2- Disconect the printer
3- Lift the scaner part of if, as you do when adding ink.
4- Look where the print head (the ink cartiges) is, this is where the stain is
5- Get the print head out of the way (just slide it left or right)
5- Use a soft cloth with little water to try to clean it, if it doesn't work try isoplopile alcohol because sometimes the stain is ink and is very hard to remove
6- Try print again and repeat as necesary
if you can't clean it this way you must remove the strip and clean it.
(You must have plenty of time and patience to try this, or you can dissasembly the printer entirely if you want to re lubricate or something)
1- Move the printer head all the way left, and with some pointy object pull the metallic wire holding the the strip at the right edge (flashlight very usefull), it's marked with and "D", remember that.
2- Move the printer head to the right and remove the plastic strip (this side is very easy), it's marked with an inverted "F" (it's on the other side) and an arrow indicating the up direction
3- Inspect how dirty is the strip and clean it the way you want (not so aggresively, the strip hasn't the fault)
4- Put again the left side of the strip and make it pass behind the print head
5- Move the print head to the left
6- Put the right side of the strip whatever you can, this is a very tedious process because the reduced space available, remember to keep the left side in place, because it's impossible to put the right side first.
7- Re connect and power on your printer, if it immediately gives hardware error 502, the strip is misplaced, move it a little up, down, backward an forward trying to get in place and try again, or consult the respective solution en this website.
8- If you can turn on the printer it should print now, try it, if it works, Congrats!
Sorry for my bad english
Feb 14, 2009 | Dell A940 All-In-One InkJet Printer
Kodak EASYSHARE Printer Dock
Well it's not looking to pomising by reading all of the other people who are having the same problem. But could you please tell me how to fix my printer in is only printing half of my pictures no matter how many times i reprint them and it also doesn't pick up the printing paper very well i have to help it along. So if you could PLEASE tell me how to fix this problem on my own it would be greatly appreciated. Please respond As Soon As Possible Please and Thank You. I have the Kodak Easy Share Printer Dock Series 3.
Patricia Davis
Nov 03, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
Kodak Easy Share Pinter Dock
Hi, Found the described bar with the adjustment screws for the
springs. Tightened them and it seemed to move the picture over
about 1 extra centimeter of the picture. I tightened it further and screwed down the three allen wrench adjustment screws attached to the black electronic plate and got now half of the picture to print. So this is definately related to the pressure applied to the paper during the transfer of the image from the black electronic bar through the print cartridge film. I then noticed that the left plastic lever grommet (opposite side from the gears) that is used to push down the printing aparatus during printing was cracked and able to spin a bit around the metal dowel. This metal dowel has two plasting levers attached and the one without the gears seems to have had wear and tear and finally cracked. The pressure applied to the left side of the paper is now not enough due to lever being cracked. My screw tightening didn't cause this. So..... I took the dowel out by unhooking the gear side and lifting it out. I then fit the plastic lever in the dowel correctly (there is a flat part of the dowel showing the proper placement) and applied liquid nails (or super
glue would work probably) to the lever to permantnely attach it to the dowel. I'm now waiting for the glue to harden. This should
get my printer back. I sure wish you could purchase spare parts for these things and that they wouldn't make these "wearable"
parts out of plastic. Anyway.... I'll repost with my results.
Nov 26, 2007 | Kodak EasyShare Thermal Photo Printer
E-mail images
What is the Macro function used for? The Macro function allows you to take close-up pictures. Use the Macro mode when you are 8.4” to 19.2” away from your subject. Where is the Reference Manual for the D-390? The Reference Manual is located on the Camedia Master CD-ROM and is available in four languages (English, French, Spanish, and German. The manual can be viewed on your computer screen or printed on your printer. How can I get traditional photo prints from my digital camera? Most photo processing centers or digital printing Kiosks can make traditional photo prints from a digital camera. There are also many on-line photo processors which conveniently deliver prints by mail. You can also make prints yourself if you have a photo quality printer like the Olympus P-400 printer. Why are there so many quality settings? Different quality settings are used for different purposes; for example, lower quality settings can be used to e-mail pictures because of its small file size. Higher quality settings are used for printing photo quality images. What settings should I use to get the best picture quality? The best picture quality setting on the D-390 is SHQ (Super High Quality). The SHQ file is the largest of all four quality settings. The image file size is approximately 786K. What is the video output used for? The video output is used for viewing images from your camera to a TV. A slideshow can be accomplished by using the camera hooked to the TV or recorded from a VCR. When taking macro images, can I use the viewfinder? Since the viewfinder sees the subject different than the picture taking lens, we recommend using the LCD monitor screen for taking macro pictures. The image previewed on the LCD monitor will be the exact image that is taken. How do I make a Panorama picture? You can easily make panorama pictures with your D-390 by “stitching” together multiple pictures. First, activate the panorama mode on the camera by selecting Mode Menu - Camera - Panorama. Take your pictures while making sure to overlap the edges of the images. Download your pictures to a computer and then use the “Panorama” function in Camedia Master to stitch them together. For more detailed information, please refer to the camera documentation. What is movie mode function? The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode. Can I add sound to a movie made with my D-390? The D-390 does not record sound in the movie mode. What is the best way to e-mail images? E-mailing pictures that were taken with your camera is as easy as attaching a file to your message.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Kodak EasyShare Printer Dock Series 3 Logo
280 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
