Back to:
Tags:
Washing Machines
Generic problem for all Washing Machines
Musty smell in washer (by 6 users)
posted by foodieroo on Mar 25, 2008
musty smell coming from wash tub
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by frsyth88, posted on Oct 03, 2008
I have the same problem. I have tried 1 gallon of bleach in about 2 weeks and also tried to run 1 cycle before thinking that it wasn't draining all the way but STILL SMELLS bad thing is that it is a Frigidaire. Help needed
Comment by Guest, posted on Sep 29, 2008
My washer smells like mold and my laundry is coming out smelling of mold too. I ran bleach through, which helped a little bit. My sister has a Maytag and she had to have her rubber seal for the door replaced, shoul I?
Comment by jimni12002, posted on Sep 28, 2008
I have a musty smell in the washing machine & laundry smell terrible. I am very un happy with my new washing machine.
Comment by hrkenner, posted on Aug 10, 2008
the washer stinks when it is in use, and the clothes smell when they are finished being laundered
Comment by cathykowloon, posted on Jun 26, 2008
Musty smell in washer even though I put it through suggested monthly maintenance (special cycle with bleach added).  What's going on with this?
Solution #1
posted on May 07, 2008
Not Rated (0)
garypdh1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
From another consumer with the same problem:
The mildew smell started about a month after we got it and got increasingly worse! Had a service tech out who replaced the gasket, but he left me a product called WHIRLOUT. It is made for hot tubs and spas and whirlpool tubs. You can get it at a pool supply or Home Depot or Lowe's. It is made to remove the soap scum buildup that provides a growing environment for the bacteria, which produces the smell. You add about a cup to the normal wash cycle. Do not put in the dispenser, add when the water is in the tub. I ran it through twice the first time. Then about once a month to keep it clean. Another thing he told me, don't use dryer sheets in the dryer because they will eventually cause a film to build up on the sensors that tell you when the clothes are dry. I've switched to Downey fabric softener in the washer. He also told me NOT to use a really thick fabric softener because it will not go easily through the dispenser. There is a drain hose by the filter on the washer - pull it out first and drain the left over water into a bowl or pitcher before you clean the filter. This will prevent the mess when cleaning the filter!!! LG never told me this, the same technician showed me this, too!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Musty smell in washer:
I don't want to Accept this solution
Solution #2
posted on Mar 25, 2008
Not Rated (0)
tannerdise
Rank:Guru Guru
Rating: 87%, 52 votes
Try running some ammonia through it and see if it clears up.
Thank You!
Can you Help with these Washing Machines problems?
GE WDSR2080D Top Load Washer
my washer fills up with water, but when it starts...
Washing Machines
I bought my washing machine almost 10 years ago and it is...
Washing Machines
The whirlpool Ultimate Care II washing machine empties but...
Maytag Atlantis MAV6000 Top Load Washer
i have a maytag atlantis mav6000 top load washer and it...
LG WM-1832C Front Load Washer
I have an LG WM0532HW front load washing machine that...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
