Question about HP LaserJet 2420dn Printer
Does not print, get error message - HP LaserJet 2420dn Printer
    Scholar:
  • 118 Answers
Unplug, wait a minute, replug in. try it
check cartridges and rollers to insure nothing is blocking the printing formation.
is there too much paper in the tray?
hp has an awesome trouble shooting web site as a last choice.
Posted on Apr 29, 2010
Why my canon ir1133 printer is showing e733/0000 error message?
ERROR E733-0000 Stops printing and shows sign "Turn ...
www.fixya.com/support/t21602993-error_e733_0000
Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
Oct 29, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Error 50 c
  1. Power off your printer.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Hope this helps.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Action :
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Error Message problem
Try to find anything that prevents the printer form moving the paper or print head. If everything is fine try reinstalling the printer driver.
If that does'nt work... get your printer serviced.
Oct 18, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP LaserJet 2420dn Printer Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
