Question about GE GSH22JFT Side by Side Refrigerator
Freezer is working but not the food side
I have a GE refrigerator, the food side of the fridge is not working but the freezer is.
  • GE Master
  • 43,501 Answers
Posted on Apr 30, 2010
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Ge Fridge not cooling
Make sure that the light in the ref side is not staying on when the door is closed. Could have a bad door switch. Probably have a defrost problem in the freezer. Check to see if there is a lot of frost build up on the inside/back of the freezer. If there is then you have a bad heater or defrost thermostat or a bad timer. Also another possibility is make sure the freezer fan is working. If there is no circulation of air then the fresh food side will get warm. Then replace evaporator fan motor.
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser keeps running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Side by Side is getting too cold on the fridge side.
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
GE PCG23NHMF side by side fridge freezer - stopped cooling
Although this machine is supposed to be frost-free (i.e. automatic defrost), there was a build up of frost. We manually defrosted the machine, then restarted it - the noise has stopped and the freezer and fridge are now working. However, this may be a temporary solution.
Jan 18, 2009 | GE GSS25LGM Side by Side Refrigerator
GE fridge: Freezer working but fresh food side not cold
The problem is the refrigeration evaporator, located in the freezer section is blocked with frost and ice and not air can pass through it. Four different failed parts can cause this problem. The defrost timer, the defrost heater safety thermostat, the defrost heater, or the evaporator fan motor. Unless you are very good with a volt-ohm meter, it wiil be difficult to distinguish which one of these parts has failed. A qualifed refrigeration service tech or a good appliance service tech with a refrigeration certification can find this quickly.
Jan 13, 2009 | GE 22.0 Cu. Ft. Side-by-Side Refrigerator...
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
GE GSH22JFT Side by Side Refrigerator Logo
144 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
