Question about Hotpoint NBXR463EBWW Electric Dryer
Dryer will not start
Hard to start espically when loaded and cold...once it gets going it woeks fine...
  • Hotpoint Master
  • 43,501 Answers
My first thought is that your motor is getting weak and going bad....if your motor as a start capacitor it could be that but not likely...I would replace the motor...
A dryerdryer will not start - 2_bing.gif may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 29, 2010
Where is thermostat located on ge dryer,starts hot then it gets cool
Dryer possibly overheating due to plugged vent. They will go into a safe mode and shutdown the heater if not enough airflow. Results in starting hot but ending with a cold load of clothes! Check the belt to ensure the dryer fan is working and that the drum is properly rotating. If OK and the vent is clear then check the thermostat. Depengin on the type (Gas vs electric) there are a number of limit thermostats as well as a main thermostat. Likely you have a a limit switch kicking in to shut off the heater. Normally from lack of airflow (plugged vent, fan broken, etc...) Once unit cools down will start back up but shut down again once the heater comes on. Also check to see if the heating element is shorted to the side of the metal case. Will heat up and be intermittent.
Jun 10, 2014 | Dryers
It wont start without using either once it is hot it runs fine and starts fine also. fuel pressure with key on not running is 54lbs and holds?
I don't have the specs in front of me but that sounds resonable. I'ld check ignition. Espically the plugs.
Jan 12, 2010 | 1996 Chevrolet Blazer
Hard to start cold but once running is ok
I believe you have a throtle body correct? IF so you have poor fuel pressure, plugged filter of injector.If by some miracle you have a carberated engine the the fuel is leaking from the bowl. Get a carb rebuild kit.
Aug 23, 2009 | 1987 Chevrolet Blazer
When the dryer in on I smell fumes.The flex hose was removed and there is nothing in it. The fumes do not smell like gas fumes such as from a gas leak It is an older Kenmore dryer that woeks fine.
Did you recently do some painting or varnishing in the house? These and home perms will mix with the burner and leave an awful smell behind.
Eric
Aug 08, 2009 | Kenmore Dryers
No heat after drying several loads
the vent in your house may be stop up in the wall.
Jun 15, 2009 | LG DLG3788W Gas Dryer
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
WM3988HWA Pumps Cold Water in Drying Mode!
Replace the 5 way valve. get the old flow restrictor out of the drying cold water line before reconnecting. It came out of the valve to cause the problem.
Oct 17, 2008 | LG WM3988HWA Front Load Washer / Dryer
Starts cycle and then stops
Jirina, first check to make sure that both the hot and cold water valves are turned on. If that's ok, check to make sure the lid switch is being actuated. Check those first...Catriver.
May 29, 2007 | Whirlpool LTE5243D Top Load Stacked...
Hotpoint NBXR463EBWW Electric Dryer Logo
67 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
