InFocus model LP 530 projector. I replaced a burned out bulb in Dec. It has gone out again. Bulb looks OK. Bulb company suggested resetting the bulb timer. How do I do that? thanks for your help.
    Genius:
  • 1,043 Answers
Please do the following to reset the bulb timer: Press and hold the Volume button and then press the Menu button. Hold both buttons down for 10 seconds.
If you don't already know how this is the way to check your bulb's hours: Press the Menu button then select Status. After 2500 hours the LED flashes orange and the lamp will not light until the light is replaced and the timer reset.
Posted on Apr 29, 2010
After bulb burns out during church service and fan is running when power is turned off and bulb is replaced. Projector will not power back up.
Hi, I would suggest that you give it more time to cool down in the future, that is why bulb burned.
There could be more heat damage to projector. Check for reset botton and push carefully. listen for click. Look at main switch with more detail (worn out) Bring to be repaired. Good luck.
Jun 13, 2011 | InFocus DP8200X R Refurbished LCD...
Infocus IN72 - blinking RED light
firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
Mar 03, 2010 | InFocus IN72 Multimedia Projector
InFocus LP530 with burnt original power unit. To use a new bulb, what is required to upgrade the power unit? (Apparently, 5 resistors need to be changed)
unfortunately, infocus no longer makes or even carries parts for that model. you could try getting a bad one on ebay that has a different problem and swap the parts.
Dec 14, 2009 | InFocus LP 530 Multimedia Projector
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
InFocus LP240 Projector won't turn on.
there is a fuse on the power supply next to the plug (on the inside), but this model of projector has power supply issues. the biggest being that infocus no longer has parts, schematics, or component cross references for the lp240. the circuit boards were made by another company that made had their own components and now no longer makes circuit boards (they make fans and bearings), and they have no schematics either. so, i'm sorry to say that the machine is doa. there are no replacement parts available and almost no way to fix the old ones.
May 19, 2009 | InFocus LP 600 Multimedia Projector
I have an LP530. Need main circuit board
Try LumenArc. They stock a range of ballasts. If yours is not listed, then email them.
May 09, 2009 | InFocus LP 530 Multimedia Projector
Infocus LP530 no power
the power supply needs replacing. sometimes the caps are dried up, but show no signs of damage. when the caps doesn't work, the ps doesn't work.
May 07, 2009 | InFocus LP 530 Multimedia Projector
Infocous LP 530 Light comes on then stops
this could be one of three issues. the power supply. the firmware or the lamp. thebulbman.com
Feb 03, 2009 | InFocus LP 530 Multimedia Projector
Infocus lp 530
Hello, That should absolutely reset the lamp timer.
This is crucial: Press and hold the volume - button, then press the source button (while still holding down the volume - button) for 5 seconds.
Make Sure you hold them both down for 5 Seconds!
I hope this helps you.
Cheers
May 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
LP 530 Lamp does not power on
Did you cancell the bulb fault status in the main menu ie bulb hours when you changed your bulbs if not try this turn unit on and see if it works it may do.
To reset the lamp hours counter press and hold down the Volume minus button - , then press the source button whilst still holding down the volume button for 5 seconds .
If this works you can then verify that the lamp counter was reset by viewing the counter in the status window in the OSM
hope this helps... Regards Vortash
Feb 27, 2008 | InFocus LP 530 Multimedia Projector
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
