Question about Dryers
The diagram of how the dryer is connect to the heating unit
  • Dryers Master
  • 8,220 Answers
A typical Diagram
Posted on Apr 29, 2010
How to fix clothes dryer that works but takes very long time to dry. Dryer vent was cleaned thoroughly.
the heater portion of the unit not working, with out any type of machine configurations or layout diagrams, and where to even start.
heating unit, check for fuse, reset button, wiring is secured, connections or connected, no broken wires,
try going to the manufactures web site, look under the FAQ section for help, if you dont get any help call the manufacture service center ask for tech support where to start.
www.ask.com/
www.howto.com/
www.hwto.com/
www.infolinks.com/
www.searchfiles.org/
www.wikipedia.org/
www.about.com/
www.search.com/
/mfg.name/make/model/troubleshooting/unit/will/not/heat/
Oct 22, 2015 | Dryers
Does it have a heating element
Yes, as with all dryers, this unit has a heating element. This site: http://www.searspartsdirect.com/partsdirect/part-model/Fisherpaykel-Parts/Dryer-Parts/Model-DEGX196010B/3068/0151200/P0606083/00006?blt=06&prst=&shdMod= has a diagram of the dryer including the pair of heating elements. See part 3 in this Dryer Base diagram.
I hope this helps.
Aug 19, 2014 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool wiring diagrams
Need to be more specific on unit. Model, Serial Number. Should be inside the door!
Nov 13, 2017 | Dryers
My kenmore elec. dryer 67042 model wont get hot...I never recd a manual..need diagram to dis assemble and examine the unit! Can u help me find a diagram?
Make sure the unit is not plugged in when testing these fuses.You should also check the continuity on the heating element if all fuses check out as good.You may also need to check the main power at the terminal block and make sure you have 220 volts to the terminal block.These are all located on the rear of the dryer remove the back panel to get to them.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Mar 19, 2011 | Kenmore Dryers
My dryer no longer heats
Small Diagnostics: is the gas line open, does the dryer still operate (tumble) but it does not heat, does the exhaust blow air out if so then the gas delivery, motor, vacuum motor are possibly working properly.
website http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170716&diagram_id=28476104#d28476104
Issues might then be in the ducting or the heating unit, this is the schematic of the gas line, heating, and ducting within the core of the dryer: If you take a close look at number 16 which can be seen inside the tumbler, Sometimes the port/ matrix of small air vent can clog up due to lint. Make sure that vent is not blocked. This prevent hot air from coming into tumbler.
When a unit over heats or fails it could be related to the high limit thermostat which is a sensor that get tripped or blows when it reached its limit check and see if its fried/ burnt (number 17).
Diagram number 2: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170716&diagram_id=28476105#d28476105
This one contains or blown out thermostat fuses check and see if they are OK on diagram 2, Part number 8 Tstat and 10 thermal fuse.
Hopefully this help.
Jan 10, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Sears Kenmore dryer model number 96310100 runs but not heating. How do you check the thermostat??
Click on the below link to see the diagram where the thermostat is located.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11096310100/0582/0151200/00064690/00002?blt=06&prst=&shdMod=
Part number 8 is the thermostat on the diagram. If the unit is not getting hot, you can use an Ohm Meter to check for continuity. If the thermostat reads open or no connection, the unit is bad. If you do not have an Ohm Meter you can temporarily tape the connection on one of the thermostats leads to the other to see if it starts to warm up. I would suggest you use electrical tape and perform this operation with the unit unplugged then plug the unit back in order to test it. Do not run the dryer for more than a few minutes, or you may have to call the fire department. If it warms up after a few minutes the thermostat is defective and needs to be replaced.
Jan 06, 2011 | Dryers
Dryer continues over heating. I've replaced 2
THE IGNITER HAS TO GLOW TO IGNITE THE GAS VALVE, TRY NOT TO TOUCH THE IGNITER WITH UR FINGERS SINCE THE OIL ON OUR SKIN TENDS TO DAMAGE THE UNIT
Feb 05, 2010 | Dryers
My ge gew9250p dryer heating element is needing replacement what is a good part number for this
Hello there:
this should help you out ok
See Part # 14 on diagram.
or
See all parts for this section / diagram Heating Element (11" long x 5" wide) (Heater Element) This heating element fits later model Whirlpool/Kenmore brand electric clothes dryers. Each of its two terminals measures 5/16 of an inch, while the unit itself is approximately 11 inches long by 5 inches wide. This element carries 5200 watts and 240 volts. Appliance Help Part Number AH344597 Availability: In Stock Compare At: $56.32 Your Sale Price: $46.93 You Save: $9.39 SALE PRICE:$46.93 -->
Nov 22, 2009 | Whirlpool GEW9250P Electric Dryer
Low heat with matag dryer
I have been to the Maytag website and I could only find the installation instructions. Sometimes the wiring diagram will be located in an envelope on the unit. If the dryer isn't getting hot enough and you are sure that there is nothing empeding the airflow, then the thermostat is the only thing that can be wrong. These units are typically pretty simple.
Apr 09, 2009 | Maytag MDE8000 Dryer
Dryer Not Heating
I have the same problem what do I do to fix it?
Jan 14, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
65 people viewed this question
Top Dryers Experts
