Hi all,
After purchasing my Aspire One AOD 250 with XP home installed,I changed my OS to Windows 7, installed on C: drive, second partician is D:\ there is also one 3rd partician (hidden) I'll suspect XP is still present? however, how can I reinstall/ recall Windows xp? there is no Acer recovery software present!
First you have to create partition.You need at least two partition. One in which you intall Xp and other for win 7. WARNIG BACK UP YOUR DATA BEFORE THIS.*(You can create partion by any hard drive manager you can make a hard drive partition in control panel>administrative tool>create & manage hard drive partition) Now install xp first in one partition. If you have pre installed then avoid this step. Now install Win 7 in another partition. After you restart the machine will ask to chose your os. & just select the required OS.
If any problem appears then just put win XP disk & repair it.
You cant install win Xp after windows 7. You have to format win 7 before installing Xp. Commiting any of trick or Tweak you need to backup your data in another HD partition WARNIG BACK UP YOUR DATA
I THINK IF U GOT THESE OS ALREADY INSTALLED HAVE U GOT ENOUGH SPACE TO CARRY ON WITH THE INSTALATION ,TRY FORMATTING UR DRIVES AND TRY SEVICE PACK 2 IF AVAILABLE ,WHY DOES HE WANT ANY OTHER IF U GOT 7 ITS THE BEST OUT SO FAR
Yes you can use windows xp thereshall be no problems.
In order to use windows xp you have 2 options,
1. Install windows XP on your computer ( that will remove windows 7) 2. You can make it a dual boot where you can have both the operating systems. (win 7 amd win xp)
To install windows xp you will need a windows xp os disc with a valid license key with the help of the disc you can install windows xp.
One Possible way is to format the partition used by Win 7 OS and install a fresh copy of XP else you can enter the BIOS and then select System Configuration then Device configuration then change SATA native mode from enable to disable. Place the XP disk in the drive and reboot the system follow the instructions install the XP...
I can help you change your language, but I need to know the Operating System installed on your computer. (i.e. windows xp, windows vista, windows 7, etc...).
It would be easier if you can somehow read spanish, let me know whether you can read spanish or not. If you are not, i have to include some illustrations and icons (graphics).
hey listen if u upgrade ur OS to Win 7 then ur programs will have capabilty tu run in that OS and u'll be able to roll back ur changes after upgrade and One-touch key recovery will help to roll back ur prev version of windows
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
HELLO I AM RAVICHANDRAN FROM iRELAND, I BOUGHT THE EEE PC 900 SERIES WINXP, I GB RAM CELERON 900 PROCESSOR. NOW WIDOWS XP IS CORRPTED, WHAT CAN I DO . I HAVE A USB DVD DRIVE. HOW IS BOOT THE BOOTABLE CD. PLEASE DETAILY EXPLAIN ME STEP BY STEP
are you install OS inside you notebook is windows xp profesional SP2???? because follow my information the rest of driver can istall just by the acer cd driver only driver display and wireless you nees to download from other link internet.
