Question about Compaq Presario 700 470024-192 Notebook
Need ac adapter/power cord - Compaq Presario 700 470024-192 Notebook
  • 6,487 Answers
You can get a replacement power cord for this laptop from any elctronic or computer store near you like Besbuy or Radioshack, of you can order it online from this sites.
http://www.nextag.com/compaq-presario-700-power-cord/products-html
http://www.bizrate.com/laptop-accessories/compaq-presario-700/
Posted on Apr 29, 2010
I need a class 2 power Supply ac/dc adaptor
Shop for I need a class 2 power S... on Google
Phihong ? Wall Mount AC Ada...
$4.68
Mouser Electr... United Security Products AC2P
$15.44
ELVESsupply... Mean Well ? Desktop AC A...
$13.10
Mouser Electr... Ac Adapter For Black & Decke...
$17.99
eBay Generic Ac Adapter Char...
$5.99
eBay Search Results
    Kastar AC DC Adapter Plug-in Class 2 Transformer Power ...
    www.amazon.com > ... > Car Chargers
    Amazon.com, Inc.Kastar AC DC Adapter Plug-in Class 2 Transformer Power Supply Cord Wall .... Provides power to your device in the event you may have lost or damaged your ...
    Amazon.com: Class 2 Power Supply AC Adapter 6V 200mA ...
Dec 14, 2015 | Computers & Internet
I need power cord and AC adapter for an Acer H236HL BID monitor
You may want to call Acer support for them to send you a new power cord and ac adapter. Acer technical support number is 1-800-816-2237
May 15, 2014 | Acer Office Equipment & Supplies
I need to order USB cord/AC/charger cord I have the I7 with 8 g memory my computer serial# A4N0AS3428021G
PLease go to eBay and type in the Model# (not the serial) in their search box followed by "AC Adapter Charger" and you will have choices.
Regards,
The Selkie
Sep 28, 2010 | ASUS AC Adapter- Universal Notebook AC...
My wii will not turn on
Hi,Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Thanks and good luck
Jun 03, 2010 | Nintendo Wii Console
My 4520 Acer Laptop will not charge and will not work on AC power alone.......
You First need to test your AC Adapter Cord...
You can test if you have a secondary known working one.. plug that one in to see if same issue occurs.. OR you will need to test the AC Adapter using a multimeter (available at any home improvement store for under $7).. When testing the Plug End on the AC Adapter - Hold The Negative Test Prod Of the Multimeter to the Outer Side Of the Plug Tip, and Put The Positive(red) Test Prod Inside The Plug Tip... See If You Have Power Through The AC Adapter Tip... You Might Need To Slightly Wiggle The Cord Near The Tip End To See If THere Is A Short In The Cord....
If Cord Tests Good....
You Will Need To Replace The Laptops DC Jack...
The DC Jack is the port where your AC Adapter Plugs into on the laptop..
Your Faulty DC Jack Would Need to be desoldered, the motherboard cleaned of all old flux, Re-Tin The Contact Pads and then Resolder a New DC Jack Onto The Motherboard...
Nov 16, 2009 | Acer Aspire 4520-5582 Notebook
Laptop won't a hold charge when plugged in
Remove the Laptops Battery, Plug in AC Adapter... Is it able to Stay Powered On?? Slightly wiggle the Cord Near the plug end while plugged in... Does it still receive true power??? If So, Its Not Your AC Adapter Or Your DC Jack And You should Look into Replacing Your Laptops Battery...
If You Are Not Able To Power THe Laptop Using Just The AC Adapter When The Battery Is Removed, Then You First Need To Check/Test The AC Adapter using A Multimeter To See If You Have A Faulty Cord... If Cord Is Still Getting Correct Power Through To The Plug Tip .. Then You Will Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into on the laptop)
Nov 16, 2009 | Acer Aspire 3680 Laptop
Plug is broken
You can buy a new Durabrand Dual car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand Dual 7b portable dvd player
You can buy a new Durabrand Dual wall ac adapter by clicking on the hyperlink:
buy replacement wall ac adapter power charger cord for DURABRAND Dual 7b PORTABLE DVD PLAYER
Jun 20, 2009 | Durabrand Portable DVD
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
Power cord
This one should do the trick.
http://insidecomputer.stores.yahoo.net/ac-adapter-for-acer-al1714-al1714b19volt-l1714171419.html
Feb 09, 2009 | Computers & Internet
Power Cord
Please let me know when I can get the power cord & AC adapter. I moved and lost them and cannot use my television. Thank you R. Werkheiser
Nov 03, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Compaq Presario 700 470024-192 Notebook Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
