TV Is it good to disconnect the TV from power when it is not used for a long period of time?
    Problem Solver:
If it costs me $19.98 to solve a simple question, You FIXYa is not worth the cost. It probably cost you more to send this email then to answer my simple question. I will unsubscribe from your service.
Posted on Mar 25, 2008
SOURCE:
My Samsung tv is dim; has sound and we can see the tv its just very dim. Its not a setting; we already chevjed that.
If the TV unit that you have is a DLP than a bulb in the rear is the likely culprit and is burning out. The bulbs lasts for thousands of hours but over that period the light output reduces.
The procedure for replacing is relatively simple. Use good safety procedures including disconnecting the power cord. My suggestion is you purchase a very good quality replacement bulb installed into the module. You want the brightest bulb to get the best results,
Nov 25, 2015 | Samsung Televison & Video
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
There are pinholes developing in my screen. Can you tell me why and how to repair it?
Try connecting any other device to the TV to confirm that the issue is with the TV. Then, you can try resetting the TV to the factory settings. If the issue persists, you may try power resetting.
To reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV.
If the issue persists, you can get it serviced from the nearest authorized service center.
Jul 12, 2010 | Televison & Video
32 inch EX400 Series BRAVIA LCD TV the picture is cut off on the left hand side of the screen. adjusting the fit to full etc has no effect. Is there something we can do to fix this?
Try connecting any other device to the TV to confirm whether the issue is with the TV. If the issue is with the TV then try resetting the TV to the factory settings. If the issue persists, try power resetting the TV.
To power reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV.
Try adjusting the wide modes of the TV. If the issue still persists, then TV may require service.
Jul 26, 2010 | Sony Televison & Video
I have a KDL46VL150 that has started cutting off after viewing for a while. The standby lights blink a sequence of 6 times. Usually if i unplug or cycle power to off and wait a bit it will return to normal...
It indicates that there is an internal malfunction within the TV. You can try Power reset.
To Reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV.
You can also try connecting the TV directly to the wall outlet.
If the issue persists, I suggest that you get the TV serviced to fix the issue.
Jul 12, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
The tv has no picture but sound can be heard. how
Try connecting a different device to the TV and check. You may also try changing the cable to connect the device to the TV and check. If the issue persists, try resetting the TV to the factory settings, then try power reset. To power reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV. If the issue still persists, then service may be required.
Jul 26, 2010 | Samsung Televison & Video
Hitachi 50ux19k model that will power on and powers right off.
Replace Both of your STK ICs that will fix this they are big black ICs will have part number on them STK392-110 use 180s Mats Electronics has them 1-800-628-1118
Mar 22, 2010 | Hitachi 50UX57B 50" Rear Projection...
TV will not power up, no lights blinking just a continuous beeping sound
Please follow the below troubleshooting steps: 1. If the Television is plugged into a surge protector, remove it from the surge protector and plug it directly into the wall outlet. 2. Try connecting the TV to a different AC wall outlet. 3. Try power resetting the TV. To Reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power ON the TV. 4. If the issue still persists, TV will require service.
Jan 23, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Does not turn on, light flashes, it clicks once, the remote control will not even turn the light on
Jan 21, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Ekse
