Question about Digital Square Zillion PA30B (128 MB) MP3 Player
I look for the driver for the digital square pa30b-21
What is cubic feet in 11 feet by 21 feet
You cannot calculate cubic feet from only two measurements. Cubic feet is an area of volume, such as the inside area of a box. With only two measurements you get square feet, which is a measurement of area. A box 11 feet by 21 feet takes up an area of 231 square feet (11 times 21). If the box is 3 feet tall, then you can compute cubic feet since you take all three values and multiply them together. A box 11 feet by 21 feet by 3 feet would contain 693 cubic feet of space (11 times 21 times 3).
Feb 15, 2016 | Office Equipment & Supplies
The length hypotenuse of a Right triangle length 19cm height 9cm
The square root of the sum of 19 squared and 9 squared or about 21.
Apr 23, 2014 | Computers & Internet
Sony DCR-TRV17 - In the middle of filming, a flashing yellow square with a yellow light bulb inside the square appears wiht chimes. upper right hand corner is flashing C:21:00. I turned off recorder and...
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
May 31, 2010 | Sony Handycam DCR-TRV17 Mini DV Digital...
I need help with puzzle 100
There are 28 PINS -- Count each PIN starting from left to right on each line. (1 -- 28)
Square ( 1) Join together Pin No's ( 1 -- 2 -- 6 -- 7 )
Square ( 2) Join together Pin No's ( 4 -- 12 -- 21 -- 27 )
Square ( 3) Join " " " ( 5 -- 9 -- 11 -- 15 )
Square ( 4) " " " " ( 3 -- 10 -- 13 -- 19 )
Square ( 5) " " " " ( 8 -- 16 -- 23 -- 28 )
Square ( 6) " " " " (14 -- 18-- 20 -- 25 )
Square ( 7) " " " " (17 -- 22 - 24 -- 26 )
GOOD LUCK.........
Apr 12, 2009 | Nintendo Professor Layton & the Curious...
PA30B does not handle 512Mb SD cards. What Can I do?
i'm so totally having the same problem! Let us know if you find a solution will ya? tanx, and I'll keep on looking myself
Dec 12, 2006 | Digital Square Zillion PA30B (128 MB) MP3...
Digital Square Zillion PA30B (128 MB) MP3 Player Logo
52 people viewed this question
Top Digital Square Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Digital Square Audio Player and Recorder Expert? Answer questions, earn points and help others
