Question about Hampton Bay 46056 Callaway II Ceiling Fan
Trying to remove cover that houses the ball and pipe that hangs the fan. There is no screw to hold the ceiling mount cover to the ceiling mount. I tried pushing up and twisting but no luck. Could someone out there please help me msartin688@aol.com The model of the fan is a 54-OR. I beleive it's a hampton bay fan. HELP
  • Hampton Bay Master
  • 43,501 Answers
There should be a couple of small screws at the very top on the side of the canopy...you will need to loosen these a few turns and then turn the canopy and drop it down...
This link will help you they had the same problem as you...
http://www.askmehelpdesk.com/electrical-lighting/hampton-bay-ceiling-fan-removal-25673.html
heatman101
Posted on Apr 29, 2010
I'm trying to remove the housing by the ceiling on a Hampton Bay ceiling fan.
on most fans the housing at the ceiling is there to conceal the fan mount
it is normally held in place by a screw or clamp
undoing that screw or clamp will allow the housing to move down the pole to get to the mount
to remove that housing it will be necessary to remove the wires , the mount from the tube and then pull the housing up off the tube
can you explain why you want to remove the housing as it is only a decorative piece to finish the mounting of the fan
Jun 15, 2016 | Hampton Bay Dryers
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
REMOVAL FROM CEILING
In general, the steps are:
1. Turn off power at the breaker -- not just the light switch.
(There are still "hot" wires in the junction box when "Off".)
2. Take out any light bulbs.
3. Remove any light globes. Some screw in, but most are held by springs so just pull gently with a bit of force.
4. Remove fan blades. Most have a spring at the inside edge of the blade -- press down on the spring and push the blade toward the fan motor.
5. Remove the ceiling mount cover. There is usually a circular ring up next to the ceiling; just twist it off with your hands ("lefty - loosy, righty-tighty").
6. Unscrew the ceiling mount screws. Usually there is one or two in a "simple" hole, and two one "sliding" slots. Take out the "simple" screws, and loosen (but don't remove) the "sliding" screws. Be careful not to drop screws or washers into the fan motor.
7. Twist off the ceiling mount cover to expose the wiring.
8. Disconnect all wires. For safety, put a wire nut on the wires from the ceiling.
9. Tip the fan and remove it from the ceiling mount. Keep in mind that the fan is pretty heavy, and you're on a ladder!
NOTE: Be careful not to put any pressure on any of the blade holders, especially if you intend to re-use the fan. If you do, the blades will wobble.
10. If you're installing a new fan, you can probably re-use the mount. If you want to put up a simple light fixture, remove the mount by unscrewing the two long screws holding it to the junction box.
Jul 17, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Receiver installation issue
Most of these fans locate the receiver on the mounting plate (metal part fixed to electrical box where ball hangs). The canopy (decorative part that covers the wiring on ceiling's electrical box) has enough space to hide it. I presume you're missing the manual, so install the fan and slip the receiver in the plate, right between the electrical box and the ball, everything's color coded, securely wire cables from ceiling to power cables in receiver and cables from the receiver to the fan. Slide canopy up and securely fasten with provided screws. Good luck!
Nov 01, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Hello, I need code for model UC7067RC Hampton Bay ceiling fan. There are numbers 1234 and remote does not work Please help. Thanks
Call Fan Man Lighting in Minnesota at 1-866-600-3267. They have 30 years experience and helped me with my UC7067 problems.
Oct 14, 2009 | Universal Remote Control Hampton Bay...
Cannot remove casing around ceiling. Hampton Bay
Try twisting the bezel (cover) counterclockwise to unlock it from the mounting base plate on the ceiling. The other option is to see if the bezel/cowl has fasters (screws) holding it in place either from the sides near the top edge or at the bottom nearest the narrow portion of the cover.
Sometimes the fan cowl bezel is fastened using screws at the point nearest the motor shaft.
There could also be a trim ring that needs to be gently pryed off from the edge nearest the ceiling, so you can gain access to the screws that are holding the cowl in place on the mounting plate. There are usually 2 sets of 2 screws placed 180 degees apart from each other that secure the cowl in place.
I hope you find this Very Helpful and best regards!
Aug 20, 2009 | Hampton Bay Dryers
How do I get my hampton bay antigua fan down from the ceiling
first you will need a ladder and a screwdriver/phillips a couple wire nuts or electrical tape.at the "top" of the fan you will see a bowl shaped cover it will have usually no more than two screws in it..loosen or remove those screws to access the fan hanger inside.once you get that far inside you will see several wires .undo each wire seperatly and cover with a wire nut or electrical tape(please make sure your power is off to that circuit) once you have unhooked all the wires from the fan and secured them out of the way. lift the fan out of the hanger itself (sometimes it is easier to remove each blade from the motor housing before removing the fan from its hanger ) those screws can be found at the base of each blade on the motor housing..If you are moving or adding a cieling light be sure to remove both parts of the fan hanger..the second part will still be attached to the cieling..usually two screws holding it into place..if just replaacing the fan,,you can sometimes leave the second part there and hang the new fan with it..
Jul 30, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Mar 10, 2008 | Hampton Bay AC414-LRU 52'' Kemper...
Fan removal
first- remove the fan blades, next around the canopy there are three screws. remove these and the canopy will drop down. the fan will be hanging on a semi round ball in the mounting bracket. the circuit board should be accessible above the bracket.
Aug 18, 2007 | Hunter 20531 Vista Brushed Nickel Ceiling...
Hampton Bay 46056 Callaway II Ceiling Fan Logo
306 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
