Question about HP Pavilion a420n PC Desktop
Hp Pavillion a420n blinking light
Hi
i left for spring break and turned my computer off. when i came back and tried to turn it on it wouldn't. so i looked in the back and saw that there is a blinking green light and its not solid. I tried the methods to turn it on like switching power cords,taking it out and holding the power button, and switching the voltage switch but nothing works and nothing happened while i was gone like a power outage or anything.what do i do? please help
  • dkillian Jan 13, 2009
    I have the same problem with this machine. The light only blinks and there are no sounds. The system will not boot at all. I have tried what you suggested and it hasn't worked.
  • Anonymous Mar 27, 2009
    I have the exact smae problem with the blinking green light in the back of the tower and on button in front won't light up when I press it.
    Genius:
  • 1,226 Answers
Hello!
Is the pc has blinking power in it. or do your hear any beeping sounds? but anyway you can do check your PC. unplug the pc and open the system. remove and clean the memory and insert it again. and fix all connection inside the pc maybe some cable lessen. after that test the pc. and then tell me what happen i will give you more solution in it. melnavz
Posted on Mar 25, 2008
One of my ac's light is blinking and wont turn on. Is not the control batteries, what could it be?
Laptop Won't Turn on, Blinking lights - HP Support Forum ...
h30434.www3.hp.com > Laptop & Notebook > Boot
Solved: Hello My laptop is an HP pavillion dv6z-1100, its running a 64 bit version of windows 7 ... Message 1 of 38 (164,169 Views) ... Upon attempting to turn it back on (while being plugged into the ac adapter) the computer would power up, ...
Air conditioner light blinks - Discussion on Topix
www.topix.com > Chevrolet Malibu
Jul 11, 2006 - my 2001 Malibu has this problem, blinking A/C light. ... On the control panel for the air conditioner, the ac button(the one with the little green light) blinks on ... The ac will turn itself back to outside air after it has been running on ... 2002 A\C Blinking
May 14, 2007
2003 Toyota Camry A/C button flashing
Apr 10, 2007
More results from www.topix.com
Dec 25, 2015 | Computers & Internet
My hp pavillion a420n keeps shuting off and turning itself on every once and a while. Also othe flash keeps crashing and programs keep failing. Any clue what it may be telling me?????
Hardware failure - the voltage to the processor is unstable because either the PSU or the rectifiers on the motherboard have aged. Open the case and look at the motherboard - if some of the capacitors on it are bloated then you will have either to replace them or the entire board. If the capacitors are fine in there then the fault is in the PSU - you can get a new one for less than $20 at every pc shop.
Jun 03, 2011 | HP Pavilion a420n PC Desktop
Hi. I went to switch on my HP Pavillion Laptop one day when it unexpectatly froze during startup. I clicked the power button of the laptop and everything seemed fine with the lights turning on and the...
That blinking cursor is the way in which the BIOS of the laptop is telling you that it can't load Windows because it's too corrupt There's nothing more you can do apart a full reinstall. Use the recovery disk that has came with the laptop when you bought it.
Jan 15, 2011 | Computers & Internet
My HP a420n won't start after replacing cd-rw drive
Please try to remove all the connections from your computer and also connections inside the motherboard, the power cord for your hard drives and also the power cord from the power supply to your motherboard.After that, remove the memory and clean the pin by using an eraser of the pencil. And then insert again the memory stick and connect all the connections from the power supply to motherboard and everything. Lastly reset your bios and put it back to normal again. Hope this would help. Thanks..
Oct 22, 2009 | Computers & Internet
My desk top hp pavillion will not turn on
Hold the power button in on the computer for 5 seconds. Wait another 5 seconds. Now hit the power button as you normally would to turn the PC on. It should boot normally.
Dec 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
Hello.
Is the computer still its power ? if the pc has its power then try to switch on without the memory. if the system beeps means that the mainboard and processor is good. However, if the pc has no power at all then first check the power supply.tell me what happen i give you more troubleshooting.
Mar 25, 2008 | HP Pavilion a420n PC Desktop
HP Pavillion a550y
GATEWAY DESKTOP DX4900-09 GREEN POWER LIGHT KEEPS BLINKING, COMPUTER WON'T COME ON.
Mar 02, 2008 | Computers & Internet
No power
the power supply should be replaced.
Go to Blinking LED section.
Here are steps to take from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=449144&lang=en
Jan 07, 2008 | HP Pavilion a805n (PS519AA) PC Desktop
HP Pavillion A805N
Try remove and clean the memory fixed back and switch on the system.
if not solve.
If the VGA is add-on remove it and clean and fixed back and switch on the system.
if this all not solve notify me for further instructions.
HP Pavilion a420n PC Desktop Logo
250 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
