Question about Electrolux E30MO65GSS Convection Microwave Oven
Some of the 7 Digits on Electrolux Microwave Malfunction
Not all of the 7 digits light up properly on the interactive display of my Electrolux microwave model E130M045GSA. The first four digits are fine, but the last 3 digits are very faint.
  • 1214 Answers
SOURCE: How to operate Electrolux Microwave oven Model EC9055?
Here's the manual -
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0708331.pdf
Posted on Jan 24, 2009
ginko
  • 19396 Answers
SOURCE: Electrolux Microwave EMS 2487x not heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
  • 148 Answers
SOURCE: microwave on w/light but fan and heat not working
The problem is the door switch is defective. I'm on my third new switch in 3 years. The part number is 5304440026.
Posted on Oct 16, 2009
  • 1548 Answers
SOURCE: I WOULD LIKE TO DOWNLOAD MANUAL FOR ELECTROLUX
I found it! There isn't a direct link from the Electrolux home page (shame on their webmaster!), but I got it with a search engine.
The first 12 pages are important generic information about microwave cooking; after that it gets into details on your model.
Posted on Mar 08, 2011
Testimonial: "thank you very much, i was struggling to get to a manual as close to this one.I suppose this should solve my issues with the microwave:)"
johnrharlow
SOURCE: How do you change the light bulb on an electrolux
It is indeed straightforward but it requires removing the 4 phillips head screws that hold the trim kit on. Then you need to remove it from the cabinet (along with unplugging the cord.) Once that is done you will need to remove the 4 black phillips head screws along the bottom part of each side, 2 phillips from the left rear and 2 security T20 screws from the right side. I found that removing the 2 screws holding the bracket on the capacitor and the front allowed me to move the light housing enough to get to the bulb. In my case the bulb had unscrewed itself. I am not a big fan of the engineering associated with this model or the labor that assembled it.
Posted on Dec 26, 2013
How do l fix my Samsung microwave digits instead of 1 it shows 7
It's probably an issue with either the display itself, or the display driver (I.c., or microprocessor). You'd either have to replace the circuit board, or find an electronic tech to repair it.
Jan 12, 2017 | Samsung Microwave Ovens
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
Error message econ
I appreciate your post, friend!
Based off the information you have provided your Electrolux built in microwave is displaying an error code of "ECON". I am showing that this is an invalid error code. I would recommend you perform a reset on your microwave and you can do that by disconnecting the power cord for roughly ten minutes. If that does not help correct your issue I would suggest contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Mar 16, 2015 | Electrolux EW30MO55HS Built In Microwave
Electrolux combi integral microwave EMS26414W does not microwave/defrost.The display/turntable/light/grill does work
Failure should be found in the high voltage section of microwave oven.
Magnetron, HV capacitor, HV diode or HV fuse, tranformer HV secondary coil
Dado
May 27, 2014 | Electrolux Microwave Ovens
Displaying error F6. What does this mean?
It would depend on the full model number of your oven.
If it has a 721 prefix, it was made by Whirlpool (by LG) and has a stuck cook relay, which we can repair very simply for $39.95 in most cases.
So please post a new help request or contact me directly with your full model number and detailed symptoms.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Jun 06, 2011 | Kenmore 66292 Microwave Oven
Our oven's glass plate is broken i want new glass plate
After some research I discovered that Electrolux is the parent company of the common brand Frigidaire.
From the looks of it, the best place to order the part you need is from Sears Parts Direct. While there were several other parts companies which popped up, Sears seems the most legit, and the prices they advertise were actually cheaper than the other sites.
The part you need has the manufacturer product code: 5304461145
If you look at the schematic (http://c.searspartsdirect.com/lis_png/PLDM/R0908182-00001.png) you will see the tray labeled as part #45. This code matches the last two digits of the product code, so I'm fairly confident that this is the correct part.
The part is currently priced at $135.43 without tax or shipping.
You can purchase the part online at this link:http://www.searspartsdirect.com/partsdirect/part-number/Electrolux-Parts/Microwave-Parts/5304461145/0022/628/Model-E30MO65GSSB/1412/0123100?keySuffixId=&productTypeId=&searchModelNumber=E30MO65GSSB&blt=06&subCompDesc=OVEN/CABINET
Mar 01, 2011 | Electrolux E30MO65GSS Convection Microwave...
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    Kenmore elite microwave oven displays "Locked" and will not respond
    My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
    Mar 01, 2008 | Kenmore 62622 Microwave Oven
    Microwave display - digits have become dim / partialy missing
    We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
    Full details and *critical* safety, disassembly, and troubleshooting info is at Web our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
    Nov 09, 2007 | Microwave Ovens
    Electrolux E30MO65GSS Convection Microwave Oven Logo
    51 people viewed this question
    Top Electrolux Microwave Ovens Experts
    William Miller
    William Miller
    Paul Bade
    Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
