Question about Amana Washing Machines
Trouble with amana washer, display reads nd (will not drain)... I have tried to restart the washer and the cycle, nothing is happening but a faint hum. Also, the door will not unlock.
  • 1294 Answers
SOURCE: nd appears onscreen
First drain out the water from the machine with a tube. You have to check your outlet filter, likely it is clogged. Clean out and refit. Your machine will not do the spin because it knows the filter is clogged.
Posted on Jun 13, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Error COde "nd"
"nd" refers to a No Drain issue . check for rstriction in pump assy, restricted drain hose loose wire at pump, bad pump
Posted on Mar 03, 2008
I had a similar problem until it finally gave up draining altogether. I took the drain pump apart and found that a quarter was jammed in the pump after it broke a vain off. I don't know how the quarter got past the basket but this was definitely my problem.
Posted on Mar 29, 2008
  • 109 Answers
SOURCE: amana nfw7200 washer stopped in middle of cycle
is it full of water? if so there is a drain problem and may have to clean out the pump
Posted on Aug 23, 2009
SOURCE: Maytag MAH 24 does not drain and makes weird humming noise
I have the same problem...How do you manually unlock the door so I can bail it out???
Posted on Jan 23, 2011
My amana front load washer, model NFW7200TW won't drain it gets down to 8 min of cycle and stop and display nd code. Check pump, fine also I can open washer door when it get stuck in this mode
remove the drain hose from back to see if there is any foreign object stuck in there , if washer faults out on code its common for door to unlock
Aug 16, 2016 | Amana Washing Machines
Amana front load washer
nd--Washer is not draining/Washer senses a brief restriction while draining
Nov 17, 2013 | Washing Machines
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
Information code "nd" is being displayed tried restarting cycle and checking for any kinks in drain hose.
Hello,the unit is trying to drain...clogged drain hose..jammed pump..defective pump
Thanks
May 28, 2010 | Maytag MAH8700A Front Load Washer
Nd in the display
nd stands for no drain check for a restriction in your drain line and in your pump assembly
May 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Washer will not spin; displays nd error
(nd) stands for no drain check the pump,and drain hose
for clogs
Dec 24, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
