Question about Echo Rapid Loader, Trimmer Head
How to replace string on echo srm 261t weedeater when its running string slowly releases without ever tappig ground
5 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
SOURCE: Echo srm-225 string broke off inside of the spool.
I solved the problem myself. I found the manual online and followed the directions that were given. Having the manual helped because it allowed me to know how to open up the spool without damaging it.
Posted on Oct 01, 2009
SOURCE: After two years of excellent service, my Echo now
Your getting a vacuum in the tank stopping the fuel getting through after a while try loosening the gas cap a tad.... may just be your problem?
Posted on Feb 03, 2010
SOURCE: I have an echo weedeater srm 261t it will start and idle but dies when I give it gas.
nichodemus, you can thank the epa for this. All of the 2-stroke handhelds now come from the factory set up very lean. Almost every new 2-stroke that I have bought in the past few years has needed a carb adjustment, both on the low speed needle and the high speed needle. There are tamper resistant plugs over the adjustment screws on most carbs now. Unless you know what you are doing, the dealer will have to do this.
Posted on Apr 17, 2010
How do I fix a echo srm 210 weedeater that starts but will only run a few seconds?
Try calling echo and ask for tech support or go online to get the phone # or check you tube to see if they have a video on it
Apr 05, 2016 | Echo Garden
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50
    www.youtube.com/watch?v=uFN82KDj3a8
    Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
Sep 16, 2015 | Echo Garden
Why won't the string advance?
many times it is because the string has welded itself inside the head . and we have to use pliers to help it get loose again .
Jun 17, 2015 | Echo New String Trimmer SRM-225 2 Stroke...
Echo weedeater srm 230 oi l for houseing what
See section 24 of your manual here. It has the information you want for lubing the flexible drive shaft and the gear-drive housing (if your unit is so equipped). This is a manual for the SRM230S model.
http://dl.owneriq.net/0/026b46f7-c706-4d99-8444-50bb35343992.pdf
Jul 23, 2011 | Echo Garden
Feb 03, 2010 | Garden
Echo srm-225 string broke off inside of the spool. How to get it out?
Sep 30, 2009 | Echo Garden
How can I remove Echo 230 SRM trimmer head?
Don't know for sure, but I found manual on amazon, Amazon com echo srm manual so take a look if you want. have a nice day
Jul 21, 2009 | Echo Rapid Loader, Trimmer Head
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
I have an echo weedeater srm 261t it will start and idle but dies when I give it gas. It worked fine when I drained it and stored it for the winter. I have cleaned the carburator and the muffler screens,...
May 20, 2009 | Garden
Echo Rapid Loader, Trimmer Head Logo
1,033 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
