Question about Dell Inspiron Mini 10 Notebook
Cracked screen. how to remove screen? - Dell Inspiron Mini 10 Notebook
    Problem Solver:
  • 10 Answers
Which operating do you use? please send me at my e-mail, i can solve it.. moshal85@gmail.com
Posted on Apr 29, 2010
  • 153 Answers
First start with removing the cover of the start button switch ...
FIX A CRACKED IPHONE
Press home volume down and power when phone comes on take finger off power then volume then home. plug into itunes and restore software after it has installed click on new this will wipe phone to new
screen cracked you need to replace screen with another one by a sucker on the screen if will not suck do to the crack glue it on and slowly pull up the screen and remove the screen cables and the hidden cable for the screen (lift the black clip up carefully and pull out the screen in direction of the cable to come out. replace screen and put cables back on and clip cable back down.
Mar 15, 2013 | Apple iPhone4 4G iPhone 4
Logitech harmony one
  • Dear Sir:
    Turn off the power to your computer and unplug all cables connected to it. Remove the battery, if one is installed.
  • 2
    Locate the covered screws around the cracked screen. Remove the rubber or plastic covers, then unscrew the screws.
  • 3
    Gently remove the plastic frame around the cracked screen and set it aside. Disconnect any power cords or cables going into the LCD screen.
  • 4
    Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
  • 5
    Reconnect all internal cords to the screen. Screw in the frame and replace all the screw covers.
  • 6
    Reconnect the power supply and all external cables to the LCD screen and switch it on.
    sincerely. God bless you
    ernesto cuadra
    managua, nicaragua. c.a.
  • Feb 15, 2012 | Logitech Harmony One LCD Touchscreen...
    Cracked screen on 32 bravia. can it be fixed
    If just the plastic screen is cracked, and it hasn't affected any of the LCD screen underneath, you could take a stab at removing it.
    I would not recommend it, though. In order to access that panel, you have to remove the back, remove the boards and free up the panel. As it is, the LCD panel is one sealed piece, and getting at that sheet of plastic would be nightmarish.
    Now, if by cracked you mean that you have cracked areas of the screen, showers of pixels, whole swaths of black and white and other colors. You know, that kind of beautiful sparkle that can only be made by the flying WiiMote, then you need to replace the LCD panel. And for your 32"--given the cost of replacement--the repair would not be worth the expense.
    Jan 21, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
    Broken screen on Blackberry Curve needs to be
    you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
    Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
    Cracked LCD 10'2 ADVENT 4211c screen
    OK. This may be difficult for you. You need to completely remove the screen from the housing, remove the old screen, put in the new one and wire it all up. If you want to do this yourself, I can help you, but you may wish to have it done by a computer shop to make sure there will be no problems. My email adress is lmattheus@hotmail.co.uk.
    Sep 07, 2009 | Advent 4211c Notebook
    Digital camera screen broken
    A cracked screen will cost you, but maybe not as much as you think. Instead of replacing the whole , you can spend about $300 and replace the screen yourself. All you need is a small screwdriver.
    1)Turn off the power to your screen and unplug all cables connected to it.
    2)Remove the battery, if one is installed.
    3)Locate the covered screws around the cracked screen. Remove the rubber/plastic covers, then unscrew the screws.
    4)Gently remove the plastic frame around the cracked screen and set it aside.
    5)Disconnect any power cords or cables going into the LCD screen.
    6)Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
    7)Reconnect all internal cords to the screen.
    8)Screw in the frame and replace all the screw covers.
    9)Reconnect the power supply and all external cables to the LCD screen and switch it on.
    Aug 31, 2009 | Sony Cyber-Shot DSC-P150 Digital Camera
    Unable to remove screen surround on Acer Aspire 6930
    Walk into a Computer hardware shop. Of course they will have all the required tool to open the laptop up and fix the new screen.
    Mar 17, 2009 | Acer Aspire 6930-6771 Laptop
    Crack in screen need new protector screen for it
    You can buy replacements online. Try www.partstore.com
    You can remove the screen yourself, actually, on a lot of these sets, it just means lots of unscrewing to open the cabinet and get it out. If only one layer of your screen is cracked, it will be a lot cheaper. And if only the protective covering is cracked, I'd just throw it away and not worry about replacing it. That sparkly colored effect you see on white colors on the picture? That's the screen protector. Some people remove it for aesthetics.
    Mar 25, 2008 | Hitachi 43UWX10B 43" Rear Projection...
    Cracked Screen
    The backing of the screen will stay. You'll only be receiving the lcd.
    http://www.fonerbooks.com/laptop_4.htm
    Mar 08, 2008 | Toshiba Satellite A105-S4004 Notebook
    Repairing a razr
    you simply need a replacement screen, or do as I have and redneck mod one. If you get the screen take off the faceplate, (reply with email address for guide), remove the cracked screen, and glue on the new one. (WARNING, NEVER PRY OFF THE CRACKED SCREEN ON TOP OF THE LCD SCREEN) putting pressure on this could completely damage your phone. The other way is to again remove the face plate and cracked screen. then find a hard plastic or plexiglass, cit it out to size and there you go. you can even paint the edges black on the bottom side of the screen and very few will know the difference if you do this correctly.
    May 16, 2007 | Motorola Mobility RAZR V3
    Dell Inspiron Mini 10 Notebook Logo
    82 people viewed this question
    Alun Cox
