Question about HP Color LaserJet 2600n Printer
ONE PART OF THE IMPRINT IS PICKED UP AND REPEATED DOWN THE SIDES OF THE PAPER.
    Problem Solver:
  • 17 Answers
Sounds like it needs a new fuser. The fuser is not very easy to replace. the covers need to be removed and the fuser is located at the top of the machine. If you have never worked on them before pay for someone to do it. Fuser RM1-1820 this is the part # if you feel adventursum.
Posted on Apr 30, 2010
Looking for torque setting for pinion rear diff holden rodeo 4wd 2001 turbo deisel
You don't set the pinion by torque. Get it to where there is no real slop and place a sheet of notebook paper between the ring and pinion teeth, rotate it to get a imprint of the pattern on the paper. Once you've tightened the pinion nut enough to get a pattern/imprint of the teeth in the center of the pinion, you'll be spot on and adjusted. The pinion nut should be a ny-lock nut, with the nylon at the top of the nut cap so it won't loosen or move. You're done.
Oct 03, 2017 | Holden Cars & Trucks
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
How do you change date imprint to on
Select Setup, then select "Date Imprint". It's in the "Date Imprint" subsection of "The Setup Menu" section of the manual (pages 95 and 91 in my copy).
If you need a manual, you can download one at
http://www.nikonusa.com/pdf/manuals/coolpix/CP4800_en.pdf
Mar 03, 2011 | Nikon Coolpix 4800 Digital Camera
I have a Canon StarWriter 30 that I bought ~1995. I rarely use it, and have kept it in mint condition. I just tried to type something, and found that it's not printing the full characters; it's cutting...
Check that the hammer is striking the letters squarely, that the daisy wheel is firmly located in its holder , Check too that the patten has not moved up in its location. Check that the ribbon can still transfer a deposit across its entire width. (Look back at a used part of the ribbon to see the strike pattern).
Feb 10, 2011 | Office Equipment & Supplies
My samsung ML 2510 prints a black streak on each plus a watermark from previous page
If your paper setting are set corectly (normal paper) and you are getting a "ghost image" from the previous page, most likley the fuser is the problem. On rare occasions, the drum unit could be the culpret (Black lines) down the sides of the page as you indicated.
You may have 2 problems.
I would change the toner drum 1st. If the black lines go away ,yet the ghost image continues, then change the fuser as well.
Jan 16, 2011 | Samsung ML-2510 Laser Printer
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
Display states paper jam, open cover, reset... paper comes out 90% & then gets stuck... can pull paper out & last 1/2 inch has an imprint like the paper is in a vice grip
in this case I think you not choice the correcte paper if you make print from the computer go to the printer and try to choice a corect size paper ( A4)
Dec 01, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Canon mp600 printer repeated error code 6B00
After reading through earlier problem fixes, I inserted a piece of Card right through the feed system then taped all the covers and loose paper feed trays closed with masking tape. Picked the whole unit up, turned it upside down and shook it up and down and side to side quite hard. Put it back in place on the desk, undid all the tape and plugged both cable back in and switched it on. It went through a long startup process, spat out the card sheet and has worked OK since then (about 15 sheets printed).
Thanks for all the ideas in earlier fixes.
Nov 12, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Date Imprint
Throw the cam and buy a good one, this camera was bought by me to record the site photographs but with out a date imprint on them they are not even worth a tissue paper.
Feb 28, 2008 | Olympus Stylus 770 SW Digital Camera
Date/time imprint. Coolpix 2100
This can be done with photo editing software like photo shop on you computer. hope this helps. it the photo was already taken with the time stamp on at the time of the photo it will be on the photo and the only way to get rid of it is software. Hope this helps. please let me help you before you leave a thanks for tring feed back.
Aug 02, 2007 | Nikon Coolpix SQ Digital Camera
HP Color LaserJet 2600n Printer Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
