Question about Canon PowerShot SD600 Digital Camera
When I connect my Canon PowerShot SD600 to the computer, it says the device was not installed successfully. Before it used to work fine. ALSO, a couple of weeks ago I was messing around with 'libusb' and I think maybe that has to do with my problem? Help?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 10, 2012
SOURCE: POWERSHOT SD600 WOULDN'T SWITCH ON
I would first check the little plastic switch for the battery door being closed. Try pushing that in and turning it on with the battery in. Using a fully charged battery helps also. If these don't work you may have a blown fuse or component on the PCB.
Posted on Aug 06, 2008
SOURCE: Camera won't power up
Mine was the microswitch that tells the camera the battery / card door is closed. The tiny, cheap plastic protrusion that pushes on the switch broke off. Jam the switch with the end of a toothpick.
Posted on Feb 07, 2009
t00nz
  • 4738 Answers
SOURCE: Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 28, 2009
rajak2009
  • 527 Answers
Sir,
The problem seems that miniscule dust/sand particles jam the gears which moves the lens.
It is possible to turn the lens motor by hand bit by bit and remove particles stuck in the gear.
Also try restoring the factory settings and resetting the camera and seeing if that makes the error to go away. To do that, hold down the Menu button for five seconds. This should reset everything and (hopefully) make the error stop. If it doesn't, then you've got a separate problem-- come back and let us know if the error is still there. Also, if you have photos stored on the camera's internal memory, resetting the camera will delete those so make sure to download them first.
Thanks
Posted on Aug 07, 2009
1joester2
  • 74 Answers
SOURCE: Can I use an SDHC Ultra 8GB memory card in my
I would say no based on the Canon website information.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=145&modelid=12913#ModelTechSpecsAct
You could contact Canon to verify, and they might have a firmware upgrade to allow use of high capacity storage cards.
Joe
Posted on Jan 05, 2010
Testimonial: "Thanks Your hunch was correct. I have confirmed the answer through Canon Customer Service. Their website info wasn't helpful to me."
Will my Canon SD600 suport a SDHL flash memory card?
I assume you mean SDHC.
The SD600 was designed to use SD cards. The SDHC specification is backward compatible, meaning that SD cards will work in SDHC devices, SDHC cards will not work in SD devices. This is a hardware incompatibility, not updatable in firmware.
Sorry, but that's just the way it is.
Feb 24, 2010 | Canon PowerShot SD600 Digital Camera
"Device is in use by another program" error message
Mar 03, 2009 | Canon PowerShot SD600 Digital Camera
Computer won't recognize camera download
go to Canon's website and find the most recent version of the software that came with the camera. If that doesn't work then uninstall everything again, verify the device is not in your device manager anywhere then start over but DO NOT plug in the camera until you've upgraded to the most recent software version. Once fully updated plug it in and see what happens, should work.
Jan 06, 2009 | Canon PowerShot SD600 Digital Camera
I need to download pictures from Canon SD600 and lost printer cd
Connect the Camera to PC using the supplied USB cable, for windows XP and later versions the pc will identify the camera device and pop-up a window asking for "what to do next?"
Select copy pictures from camera from the displayed list.
Dec 17, 2008 | Canon PowerShot SD600 Digital Camera
Digital camera lens makes noise when extruding
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Dec 18, 2007 | Canon PowerShot SD600 Digital Camera
Canon Powershot SD600 Connectivity/Recognition Problem
You probably have too many unused devices in your computer, reboot in safe mode, and delete unused device from system devices. Not enough space here for a longwinded howto, but plenty of info on how to do this on the web. gurantee it will fix it
Aug 16, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 - Problems downloading images - same as below
did you download the canon download app or are you using the installed pc generic camera download app? it will make a diference if the computer cannot reconsile which too use. let me know and we can go from there
Jul 04, 2007 | Canon PowerShot SD600 Digital Camera
Canon sd600 Videos wont upload to my computer
they are probably avi files. Do you have windows media player installed? That should work.
May 24, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
