Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
My tub trips out upon power up was working ok last nite 28/4/2010.
  • 2,100 Answers
I don't know how you have it wired, but it is possible that the heater is on at the same time the pump starts and trips. The starter windings in the motor need all of 15 or more amps to start, that is why the lights dim when the fridge starts up. Anyway, if the heater is on the same line, same breaker, it needs to be bigger, and in 110 volt mode , you can't go any bigger than 20, but in 220 volt mode, you can go to 60 amp. that would be 30 amps each, potentially. depending on the voltage of each. Last time it worked ok because it wasn't crossing the line with a start up motor and water heater working at the same time. Now that you are totally confused. Check the breaker, see if there are 2. one for the heater, one for the motor. Hope this helps.
Posted on Apr 29, 2010
Cooking a roast in small oven last nite, all electric went, oven tripped it. Now no top oven working or main oven or fan. What has gone wrong?
When the mains fuse keeps tripping as soon as you switch on the oven, there could be a shortage in the oven, or some of the voltage is leaking to the ground. What it is causing it? I would not know. sorry.
Mar 24, 2015 | Ovens
Blank screen on dell latitude 6400.worked last nite
Try remove the battery and power cord. Then press the power button and hold it down for 10-15 seconds. put everything back in and push power button once. See if this helps it come back on. If not, you may have a bad monitor, backlight, or video output from the motherboard. Hooking the laptop up to an external monitor will help isolate that problem as to what exactly is causing the problem. I hope this helps! :-)
Feb 27, 2014 | Dell LATITUDE Computers & Internet
The power in our bar went off last nite and now one of the tvs won't cut back on. No power at all. Any ideas? Thanks
COULD BE ON SPERATE BREAKER. BREAKER COULD HV TRIPPED FROM A POWERS SURGE WHEN POWEER WENT OFF OR CAME ON. CHECK BREAKERS IN PANEL
Dec 04, 2011 | Sanyo Televison & Video
My hydropool spa is tripping the circuit breaker. I moved my hottub off the deck onto a concrete pad next to the deck last summer. No problems, then over the first winter I went out one day and the...
it sounds to me like your hot tub has bugs take the control panel apart and clean the bugs out of it. if you have ants in the area they will get into the controls and cause it to trip out. i had similar problem with apump until i found the ants
May 19, 2011 | Heating & Cooling
No power at all all of a sudden . the nite before worked ok then next day no power light or power.
I would first check to see if there is 115 AC volts at the main connection. If no voltage then check your fuse box for a tripped breaker. If there is 115 volts at main connection the lid switch may be the problem.
Nov 20, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
I'm installing a 40A 2-pole CH GFCI breaker in a Square-D panel that is supplying a hot tub. The 8-3 cable runs to a sub-panel beneath in the crawl space beneath the tub. The new GFCI trips immediately...
Try this...
You mentioned a 8-3 cable suppling power to the sub-panel. I am assuming you have a 8-3 WITH ground or 4 conductors, black, red, white AND ground.
In the sub-panel do not bond the neutral bar to the box or ground bar. If there is a green bonding screw on the neutral bar...remove it. If you have only one (1) neutral bar add another bar for your grounds and bond this bar to the box. Keep the neutrals isolated from the grounds.
I hope this has helped. If you need additional information please send me a follow-question.
Sep 08, 2009 | Electrical Supplies
P4/not booting up upon start
Hi try to open you chase and unistall all the additional slot cards and try to boot up, sometimes one of the slot cards fails and if that happens your machine wont start up until that slot cart is removed, thats how your machine protects it self
May 08, 2009 | Intel D865GBF Motherboard
POWER AND ALL THE LIGHTS WENT OUT COULD IT BE A FUSE?
check power to the unit main breaker tripped? if breaker is ok there may be loose wire connection or the fuse in washer machine has blown
Apr 21, 2009 | Dishwashers
Noise from tv
I had the same problem with a 5065. I purchased and installed a new color wheel and that solved the noise problem. The color wheel has a bearing that gets "dry", and when it fails it does sound like a fan bearing.
Jul 10, 2008 | Samsung HLN5065W 50" Rear Projection...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
472 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
