Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Our electrical went off last night and now the fax won't come on. Is there a power button somewhere?
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
My droid3 won't power on
most likely reason is battery. Battery only last maybe 300 cycles. Every time you charge it that is a cycle.
Feb 05, 2012 | Cell Phones
My Belkin F5D8236-4 v3 Router won't turn on. We had a storm last night and the power went out but the router won't turn on. I have tried to plug it into different outlets to see if that would work...
Try resetting the router. There should be a little hole somewhere on it with a button inside that you can press with a paperclip. Try holding that button down while you unplug then plug the router in while holding it (if possible). If that doesn't work, I'd suspect the storm might've damaged the router somehow. Was it plugged into a surge protector, and/or have you noticed any other issues with anything else that was turned on at the time?
Jun 16, 2011 | Belkin F5D8236-4 Router
Fax machine Error 77 What do we do?
This is a Heater thermistor short circuit, to reset it...
  1. Unplug the power, press and hold the menu button, plug in the power
  2. (hold the menu button for 5 seconds after power is plugged in). Release
  3. the menu button, now press 91, if the display still shows the error,
  4. press 99.
Most people just ignore it, I suppose eventually if the thermoster is malfunctioning you could burn the printer out. But from a cost perspective I don't think it's worth replacing.
Jun 10, 2010 | Brother IntelliFax-4100e Fax
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Electricity went out last night. when i get up this morning, it is making a high pitch squeeling noise and now none of the buttons work????? its a ge profile dishwasher
The electricity probably "surged" when the power came back on. It sounds lke the conrol board may have "fried". Call the repairman and get an estimate.
Mar 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
HE5 Dryer not working
Hello dram65,
Check the door interlock switch, if that's malfunctioning or not sensing the door is closed.. it will disable the drying function,
Regards,
Rick
Dec 13, 2008 | Kenmore 82822 Electric Dryer
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
Paper jumped problem
Do you mean jammed?
Usually they don't lie. A piece of paper is somewhere.
Apr 09, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
18 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
